Issue installing HP allinone printer,,,
I am trying to install HP allinone printer j6450, i keep getting hpupdate.msi not found
I have been trying to look it up in the internet with no sccuss.
Any input would be greatly appreciated.
Thank you,
    Genius:
  • 2,785 Answers
Plz download the correct and latest drivers and install it.
Posted on Sep 25, 2008
Hpupdate.msi file missing error message
It is an issue with a printer that was once installed or has been hooked to the PC before.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77759-2&cc=us&dlc=en&lc=en&os=228&product=3795406&sw_lang
Download the file and run the program. It will force windows to remove all traces of the Officejet software & drivers. If you still use your officejet you will have to reinstall the drivers.
Jan 17, 2013 | HP Pavilion DV6700T Notebook PC
APPLICATION HPSU -0004 MISSING FROM LIBRARY
Basically, the HPSU-0004 Error states that one or more DLLs (libraries) needed for the Update utility to run are missing.
The libraries were deleted, or pointers to irrelevant libraries were left in the Registry.
2 Possible Solutions:
The EASY solution:
1. Remove all of your HP (Hewlett Packard) Printer software from your computer and do a fresh install from the CD that came with your printer.
The Hard Solution (only do this if the easy one doesn't work):
1. Download a current version of the FULL drivers+applications (single HUGE file) for your printer;
2. Start running the file downloaded in the previous step, until it offers the option to install the software (other options might be there, such as "read the Readme file");
3. Do NOT click on "Install", but rather simply exit the Installer (cancel, exit, ...) - the reason for step 2. above was to just have the downloaded file extract in an orderly manner all the files that it (and YOU) would use for its (and YOUR) further processings;
4. Locate on on your drive the installation folder created in step 2., and -- under it - the folder "setup\hpupdate" (the whole thing should be located somewhere under the TMP or TEMP folder - just run a Search/Find for it, using your search engine of choice);
5. IF (and only if) you have located the HPUPDATE folder in the previous step (you will, normally), continue:
6. Under Windows Control Panel, start the "Add/Remove Programs" applet, and -- in the list of applications it presents -- look for "HP Update";
7. Remove the HP Update application as you would any other application (the uninstall process might end with some errors for files not found - this is normal in this case, as we already know that some files are either missing, or mistakenly pointed at, as stated earlier in this text);
8. Now go to the setup\hpupdate folder located in step 5. above, and run (double-click on) the only *.msi fie found within it (this will reinstall the version downloaded of the HP Update utility);
9. When Installation (previous step) is completed, run the newly installed HP-Update utility, to find further updates both for itself (you might not have had the most recent version) and for any other HP application that might reside on your drives.
10. This completes the process
Good Luck!
May 17, 2012 | HP Pavilion a705w PC Desktop
WAS IST HPSU-0004 WIE KANN ICH ES INSTALLIEREN
Hi!
Erstens verzeih mir bitte wegen Schreibfehler. Meine Muttersprache ist nicht Deutsch.
Jetzt zur loesung:
1. Auf der support-seite von HP suche und lade herunter die (sehr grosse) Datei welche die FULL drivers und applications fuer dein Drucker beinhaltet;
2. Starte die gerade heruntergeladene Datei bis zum Punkt wo es anbietet die software zu installieren;
3. Click NICHT auf "Install", sonder verlasse den Installer (z.B cancel). Am diesem zeitpunkt haben wir auf die festplatte alle spaeter notwendige Dateien;
4. Jetzt finde den Ordner wo alle diese Dateien gespeichert wurden. In diesem Ordner soll der Ordner "setup\hpupdate" sein. (der Ordner musste in TMP oder TEMP sein - am besten verwende die option SUCHEN;
5. Nur nachdem du den Ordner gefunden hast koennen wir fortsetzen:
6. In Windows Systemsteuerung, programme entfernen, werden wir das programm"HP Update" entfernen. Kann sein dass mache Fehlermeldungen dabei entstehen, aber das ist normal unter diese Umstaenden
7. Jetzt gehen wir zurueck zu dem Ordner den wir bei Schritt 4 gefunden haben. (setup\hpupdate), und doppleclick die einzige *.msi Datei die es dort gibt. Dadurch wird die HP Update Utility neu und richtig installiert;
8. Wenn die Installation (Schritt 7 ) vollendet ist, kann die HP-Update utility ausgefuhrt sein, um updates fuer alle Deine HP anwendungen zu erhalten.
Hoffe es war hilfreich
Beste Gruesse!
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp j6450 all in one paper jam cannot find any
Hi there, please reset the printer from printer setting option,then restart it. If you didn't find any resetting option then , uninstall the printer from computer & restart the both (PC & Printer). after that again install the printer and use it. Your problem will solve then. Thanks.
Feb 28, 2010 | Office Equipment & Supplies
J6450 Prints multiple copies
After spending a lot of time on the net looking for an answer I decided to spend some time to see what was different betweent the computers. It turns out that the 2 computers that I was having the problem on had Zone Alarm installed and the 3rd computer that it was working on did not. So I dug around in Zone Alarm and marked every HP software item as allowed. I then rebooted the computer and submitted a test page to the printer. Low and behold 1 copy as I wanted. I proceeded to test it some more and now am only getting one copy when I ask for one. The problem appears to be that Zone Alarm was messing it up. I still have Zone Alarm running, I just needed to mark HP as an accepted program under every listing in Zone Alarm.
Jun 20, 2009 | HP Officejet 6310 All-In-One InkJet...
I purchased and installed the hp officejetJ3640 all-in-one recently. I had an issue with my computer and 2 days ago, restored my computer to a previous date. I then lost my hp software that had been...
you must go to control panel of the windows.. then find and click add remove programs.. try to check if any of the printer component are installed.. the remove it.. here's how to install the printer.. 1st don't connect the usb cord to the pc.. then install it.. when the program was searching for the pritner then put the usb cord of the printer.. then so on.. try... ^^
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scan
Uninstall it!Then while u install it change the directory dont install on programs files simply create new folder then install there...
Feb 29, 2008 | HP LaserJet 2840 Printer
MSI Error - HP Image Zone
Hi ChaBair, Image zone is HPs attempt to get its customers to store, share and backup images on their servers: http://www.hp.ca/portal/hho/ize/ I would try reinstalling the installation CD again making sure the printer is off until it prompts you. This time when you get to the part where you can select what components to install document the program names just in case you do have to manually uninstall later. Anyway reinstall and when prompted connect your printer. Also before you actually try to use the printer make sure you go to the HP site and download/apply any patches there may be. This should fix your error problem and give you a good idea which of the ancillary programs to uninstall if you later desire to do that. This didn?t 100% answer your question but I believe it will in the end achieve what you?re looking for. If it doesn?t work let us know and we?ll go from there. Also please don?t forget to rate this posting when we?re done.
Jan 23, 2007 | HP PSC 1315 All-in-One Printer
66 people viewed this question
jasbo
jasbo
