Question about Sharp VL-Z800U Mini DV Digital Camcorder
Sharp vl-z8 dew light keeps coming on - Sharp VL-Z800U Mini DV Digital Camcorder
It seems that the due detector can suffer from bad soldering or soldering alteration after few months of use.
1. The (ideal but uneasy) solution consist to fix this solder by making a clean new one, I personally did it, and it worked for a few months without a problem anymore ; but then it came back again.
2. The other solution consist in short-circuiting the dew detector to eradicate the problem.
Of course, it will also mean that when real dew will happen you may use the video tape recorder when you shouldn't, but at least you should not see the problem coming back again some months later.
To know more about this dew detector circuit and how to fix it the way you want go there:
http://ataplow.googlepages.com/sharp-dew-problem
a zoomed picture of where to fix the detector can be found here:
http://ataplow.googlepages.com/sharpdew.jpg
Hope this will help as it helped me,
Good luck,
Fabien.
Posted on Dec 10, 2008
How do I locate the dew sensor for sharp VL Z8 camcorder?
The dew sensor is located in the cameras tape mechanism. This will require disassembling the camera to remove the tape mechanism and repair. This can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 21, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew lamp lights up and camera shuts down
Nov 17, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Camcorder
keep your camera 'ON'for more than 1hr.& cover it with black cloth & keep it in the dry room. regards; shailesh
Sep 02, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z800U Mini DV Digital Camcorder Logo
217 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
