Question about Oster 12-Bottle Wine Cellar - Black
Oster wine cooler fuse
I have removed the fuse per previous posts..and yes mine is blown too.
However, the local electronics store said they need to know if this is a "slow blowing "fuse or "fast blowing" fuse. they say it is critical to get the right one.
Anyone know which it is?
Thanks
K
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Posted on Sep 25, 2008
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Don't cool-no refund/satisfaction from Oster.
Ok, fist problem was unit quit working..if it quit cooling yet lights still worked inside and still had power readings on door is not power coord. If the unit stoped cooling is probably fuse and there are two of them in back of unit. One fuse clearly can be seen, the other is coated with a black shrink fit coating and is not well seen. This second fuse is the problem, you will need to replace it. I have same unit and this is what I had to do to get it cooling again.
Jan 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Strange noise coming from new Oster 5 c.f. frige...
I did not post a problem with a wine cooler...We all know that problem was caused by the wrong fuse that was installed at the factory.. My question was about the Oster 5 C.F. frige...no, I did not get any answers...No, I do not want your premium service...I just thought I may get some free insight on my problem...
Dec 17, 2008 | Oster 12-Bottle Wine Cellar - Black
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Aug 09, 2008 | Oster 12-Bottle Wine Cellar - Black
OSTER WINE COOLER
I had the same problem. I found the second fuse, which was blown, on the upper left quadrant of the circuit board (as you face it from the rear od the unit), wrapped in black heat shrink tubing. Since it had blown, I replaced it with a fuse holder and a new 5A 250V fuse. The parts cost less than $6.00 at Radio Shack. It took about 20 minutes. Lots less hastle than you rep-orted dealing with the company.
Jul 28, 2008 | Refrigerators
Fans not working
I had the same problem as other bloggers--temp would not decrease and fan did not run. . . as suggested by others, I replaced the 5A heat-shrink wrapped fuse in upper left corner of circuit board (fuse is covered in black heat shrink wrap and is in a U-shape). I unsoldered the two ends of the fuse on the circuit board (be sure you locate the correct two holes) and then replaced it with two parts from Radio Shack--a 5x20mm Inline Fuse Holder rated at 250V AC, 5A (part # 270-1238) and used a 6.3A slow-blow 250V fuse (part # 270-1066). Now the wine Refir works great!
To replace the part take all the screws off the sheet metal covering on the back of the refrigerator. Remove the circuit board from the plastic holder. I left all the wires plugged in and just unsoldered the fuse with the circuit board still connected--but to solder you will need an extra pair of hands to hold the board while you solder.
If you don't have it, get some silver solder while at Radio Shack and a thin, needle-point soldering iron tip. Radio shack has 30W soldering irons for less than $10. You really don't need soldering experience--just a steady hand. Even if you have none of these parts your total outlay at RadioShack is less than $25 for everything.
Apr 14, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
382 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
