Question about Hitachi 53UWX10B 53" Rear Projection Television
DP14G BOARD I need a DP1X - CONVERGENCE PWB / DP1X - SIGNAL PWB / DP1X VM PWD board for a HITACHI 53 uwx10b .. any help would be appreciated... gbigdaddyo@yahoo,com
  • imbigdaddy Sep 25, 2008
    Can anyone give me the proper numbers to order this and a business from which I can order this... Board is unrepair able, previous owner broke it.
    President:
  • 1,952 Answers
Click this link
bumblebeestoves.com/484.html - 92k
thanks for fixya
Posted on Sep 25, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 25, 2008
    click tis below link ..and order ur board...if its not available in tat...call or mail to below address..they will arrange tat and send u thro post...
    HITACHI PARTS','unionel.com');"http://www.unionel.com/catalog/cat_item_...
    they can be
    reached by phone Monday through Friday, 8:30am to 5:30pm.
    You may also contact us by Fax or E-mail at your convenience.
    Mailing Address:
    Union Electronic Distributors
    311 East Corning Road
    Beecher, IL 60401
    Phone:
    (800) 648 - 6657
    (708) 946 - 9500
    Fax:
    (800) 438 - 6466
    (708) 946 - 9200
  • 4,234 Answers
The part number is CS00453 and can be purchased for $468.06 fron tritronicsinc.com
Dan
  • 2,336 Answers
Looks like you can find one by clicking here.
  • Jaime Hernandez Sep 25, 2008
    Check the link I've sent you.
    Guru:
  • 1,894 Answers
May be this site would help you.
http://bumblebeestoves.com/484.html
even if it does not. dont worry. please ask for more assistance.
  • 10,594 Answers
Part Store is good choice to get many kind of TV boards.
Check required board there please.
I need to find the value of rx50 rx54 rx58 on hitichi dp1x convergence board
The DP1X was used in various Hitachi Models and those resistors have different ratings depending on the Model number. Post your model number and I can list the ratings for those resistors for you. Also do you mean RK50, RK54 and RK58 as those are convergence resistors board location prefixes that usually get blown. Double check the Prefixes.
Nov 26, 2009 | Televison & Video
How do you replace a Convergence Amp IC's on projection Hitachi tv?
The DP14G convergence repair kit from www.tvrepairworld.com is the correct kit for your model and the kit contains the parts and the CD with instructions.
Nov 03, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Incorrect resistors on DP1X PWB?
Assuming this unit was never worked on and it was actually working properly before the IC's decided to take a vacation I would recommend leaving them alone as there may have been an engineering change after the service manual was printed.
Apr 15, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Need schematic for Convergence PWB of Hitachi
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 09, 2009 | Hitachi Televison & Video
Parts
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
TV will not turn on
look for a blown fuse where the power comes in.
Nov 27, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitchai 53UWX10B colors dont line up.
I have a service manual for the 43/53 uwx10b
Oct 16, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Set will not turn on!! please help
No, all you need to do is notice all led and see which goes off first and which stay on. Then I can help you.
Oct 09, 2007 | Hitachi 61SWX12B 61" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
160 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
