Bad repair man took back panel off and decided he would just leave so i've got everything back together but i'm not sure where the two green ground wires go that ground the picture tube in the back. do they attach to the main panel or do they attach to the board on back of the picture tube it's self
  • 203 Answers
Sorry to hear about your bad luck! Be carefull if this is a crt based tv you could get shocked messing with the wrong wires. If you send me a few pictures of the back of the set i will help you locate where they belong.
Tim Nolan
Posted on Sep 25, 2008
TV wont turn on flashing red light
Which light flashes red on the set? Please respond to this same post for assistance.
Feb 11, 2013 | Mitsubishi WD-73C9 73" DLP TV
I have a 55 inch television that dosenot show a picture but the power button comes on green but turns red
Check the INPUT's make sure you are using the live one, for example it will be the CABLE or the DVD or what ever you set it up for.
Jul 24, 2012 | Sony Televison & Video
I have a vizio vp50 hdtv20a. A while back we turned it on no picture and it started to smoke. After reading a little about it I decided to take off back panel and see if I could locate burnt part. Could...
That board directly connects to the display panel---you may have a bad display panel which if is the case is fatal---panel alone will cost more than the set did when new----seen this before in the shop where I repair sets.
May 03, 2012 | Samsung Televison & Video
I need help putting my nikon s220 digital camera back together
Oh boy!!! I did the same thing once in 1964 on a Nikon F lens. I took away one important lesson from that experience; even the simplest looking lens or camera is mechanically complicated with interlocking parts. In my case, the camera repair man told me that the bill would have been $35 (that is about $150 in today's dollars) if I had not tried to fix it myself. It cost almost $100 to have him put everything back together again. At this point, anything you do will only make things worse. I would gather all the parts together and get an estimate from a qualified camera repair man or from the Nikon USA Repair Depot shown on there website. I hate to say it, but on an amateur camera you may find that the cost of repair will exceed the cost of a new camera. Good luck.
Feb 10, 2012 | Nikon Coolpix S-series
Shark steammop will not make steam
If your unit is heating up but not making steam.
And If your unit is not to clogged up to much! CLR or vinegar in the tank (pump a few times) and letting it sit over night may help. But it didn't work for me.
So I decided to take the entire thing apart, I mean everything! I don't recommend doing this, it was not easy to get back together and I'm a repair man. I cleaned all the mineral deposits from the heater using sand paper, it was that built up with deposits. Any deposits left behind will surely clog it up again. I unscrewed the small valve on the heater and used a small hat pin to Polk out all the mineral deposits that build up in the valve and the tap it was screwed into. The valve is where the steam comes out. I now could get air to flow through the valve. So I put it all back together. 2 1/2 hours later and it worked. Let me say, it was not fun putting this thing back together. So if you use tap water it will clog up the workings. Distilled Water will not leave minerals behind to clog it up. Hope this helps.
Tony C
Dec 28, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
It stopped working. This happened a few months
The wire your asking about is a ground wire. Without knowing the make or model fridge you have I would not know what it would go to. If it went to the timer, it might have been the problem the whole time. The fan is not the reason the unit froze up. The problem is in the defrost. You either have a bad timer, the ground off the timer or a bad heater. If you will respond back with a make and model number I'll be glad to look it up in my data base. You can email me at and I'll be glad to help you so that you will not have to pay $175.00 for nothing again.
Dec 19, 2009 | Refrigerators
Amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
Blue and green bulbs look like they have sawdust in them
Tubes need to be removed from set. Take off front lens with 4 screws, then remove the glass circle. Has a gasket, becareful. Do this over a sink. The fluid is a clear anti-freeze. Clean inside with Formula 409 and paper towel. Rinse with water and dry. There is a plastic expantion chamber on the side. Pull that out and clean it too. Put the tube back together. Note where the wingnut was when you took it apart and oriantate the lens to go in the same way. You can use a turkey baster to refill the tube through the expantion chamber opening. Fill it up as much as possable. Put chamber back on. Put tube face down for awhile and check for leaks. That round gasket can be reused sometimes, but check it first. Then put it back together and that's it. You'll have to unplug the board on the end of tube and the ground wires. Then unplug 2 seperate for the yoke and the other for the convergace. Make sure you mark the wires you take off and the way the tube came out. Everything must go back the same way it came out. Fluid can be purchased at Only need to do blue and green. Red never goes bad. Do one at a time. That's about it.
Dec 22, 2008 | Philips Magnavox 51MP392H Rear Projection...
Green images on LCD and Green on PC once uploaded
White balance settings may be changed. Go to the menu select WHITE BALANCE then select AUTO in it , then OK then return, now try.
Mar 22, 2008 | Nikon D40x Digital Camera
Televison & Video Logo
Top Televison & Video Experts
