Question about Kyocera FS-1118MFP Laser Printer
Error C6000 is showing, can you tell me if I can fix myself or call for service.
Kyocera FS-1118MFPF
Error C6000 is showing up, can you tell me if I can fix myself or call for service.
  • Anonymous Nov 18, 2008
  • 40 Answers
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Posted on Jan 12, 2009
  • 1 more comment
  • sarikaya Mar 25, 2011
    the menu does not open. could you help what should I do?
  • malik amjad Jul 13, 2013
    do not show menu for go to maintance mod whats i do
  • Cesario Cabahug
    Cesario Cabahug Jul 23, 2015
    theres no service in menu/system.. what should i do??
The menu does not open. What should I do?
Posted on Mar 25, 2011
  • tonymuga Jul 22, 2013
    hit 10871087
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
Feb 26, 2016 | Copystar Kyocera Taskalfa 181 Copier
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How do I unlock my printer a Kyocera fs 1118mfp when error C6000 appears?
Press the system menu/counter key,Select Service setting using the up/down cursor keys.While pressing the start key and the # key, press the enter key.then select 163 Resetting the fusing problem data Description Resets the detection of a service call code indicating a problem in the fusing section. When a service call concerning the fusing section occurs, turn the power switch off and open the front cover. Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode. Purpose To prevent accidents due to an abnormally high fusing temperature. Method 1. Press the enter key. A selection item appears. 2. Select Execute using the up/down cursor keys. 3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.) Completion Press the back key. The indication for selecting a maintenance item No. appears.
Mar 27, 2015 | Kyocera FS-1118MFP Laser Printer
ERROR COD C6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera FS-1118 Printer
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
Resettare codice errore c6 su kyocera fs 1118
If the code is C6400, then just follow the procedure showing in the images below.
If the code is C6000, then you have to remove the fuser unit and check the thermistor, the thermal cut out and the heater lamp. If are able to fix the problem-damage, then follow the procedure below to reset the service call.
b6abe89e-6db1-403f-b1d5-10039126b726.jpg 6bbf89df-5e1f-4ba9-830e-5fa3e278ce55.jpg
Mar 16, 2014 | Kyocera FS-1118 Printer
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
I'm having an error on my kyocera ecosys FS 1118MFP. The message is "Error Occurred. Power switch turn off and on again Cf2ff". Please can you help?
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Jan 14, 2009 | Kyocera FS-1118MFP Laser Printer
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Aug 02, 2008 | Office Equipment & Supplies
Kyocera FS-1118MFP Laser Printer Logo
3,937 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
NewYork kyocera HP...
Soulvisitor
Soulvisitor
Tech Bravo
Tech Bravo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
