Question about RCA P52926 52" Rear Projection Television
T.v. tube explosion
I am replaceing a tube tv in a wood 1980's box with a fish tank. i a'm scared that if i camage the t.v. im going to make it explode. is this true?
  • 50 Answers
LOT OF PEOPLE DO THAT...I'M ALL FOR GREEN---THE ONLY DANGER IS THE PICTURE TUBE AND YOU NEED TO BE CAREFULL-- TAKE THE METAL CHASSIS OUT OF THE TV ,,YOU CAN USE WIRE CUTTERS TO REMOVE THE WIRES ETC...,AFTER THAT ..CAREFULLY LAY THE TV FACE DOWN ON A BLANKET,,REMOVE PROBABLY 4 SCREWS ON EACH CORNER OF THE PICTURE TUBE,,AFTER THAT ,YOU AND A FRIEND CAN LIFT THE TUBE OUT ....TUBES ARE MEANT TO "IMPLODE" NOT EXPLODE....ALWAYS WEAR SAFTY GLASSES AND BE CAREFULL...IF YOU DON'T FEEL COMFORTABLE ON THIS ---DON'T DO IT ....TUNICA
Posted on Oct 30, 2008
How can I replace fuel gauge?
You did not post the year make and model but the fuel sender unit is in the tank and it can be dangerous and laborious to replace. You have to drain the tank, unhook fill tubes, lower the tank, unhook the fuel lines (takes special tools) remove the cover, replace the unit, replace the seal, put the cover back, put the lines back, put the fill tubes back. This might mean using a jack to raise and lower it and all the time not cause an explosion or fire. It is not a one person job.
Feb 06, 2016 | Cars & Trucks
Got a smoker with instructions but it does not say where to put the wood shavings?
Is it charcoal or propane? If charcoal, you can either use a metal smoke box or place the soaked chips directly on the coals. If it is gas, the metal smoke box is the route to go. If one did not come with the grill, they are readily available at most big box hardware stores (Lowe's, Home Depot, etc) for a reasonable price. An easy substitute for a metal smoke box is making a single use one with aluminum foil. Take a sheet of foil and fold it in half, place your chips in the pocket, seal the edges by foling them over, use a knife and cut a few small slits on one side of the foil, place foil pack on fire (slits on the top side). Discard after use. Works well with wood chips or herbs such as rosemary and thyme.
Jan 26, 2013 | Bass Pro Fish Cooker Kit Grill
Why would I use artificial wood decorations in my aquarium? I can just get small wooden pieces for free in my yard.
The wood from your yard may possibly release toxins in your tank that will hurt your fish. Artificial wood is a great option. Not only does it look nice in the tank, but it is easy to clean and will last a very long time.
Aug 29, 2012 | Alpine Fish
Can I make my own fish food dispenser for my tank? I really don't want to spend more money on my fish.
You can try making your own. But make sure you try it out for a few days before you go away just in case there is a problem.
Aug 26, 2012 | Archos Fish
Chain saw won't keep running. runs and stalls
Hi there, Sounds like you need to change the fuel filter.Use a piece of tie wire with hook on one end and fish out the plastic tube with the fuel filter on the end. Hemostats can be used also.Use a turkey baster to **** the gas and trash out of the tank.then pour in a pack of BB'S cover hole and shake the saw.This will loosen any stuck trash and when you put some gas back in it will come out with the turkey baster.The next step is buy a spray can Berrymans carburetor cleaner (any carb cleaner will do.) I recommend saftey glass's for next step.Stick the carburetor cleaner nozzle straw in the tank tube and press the saw trigger like you were going to cut wood,spray cleaner and open and close saw trigger 4 or5 times.If you do this with the carburetor filter off, place a clean rag over the carburetor.When you think it's clean hold the trigger open until the cleaner dries and then install gas tank filter.Now spray carburetor and linkage on the outside.Install clean filter and cover.With new gas&oil mix in tank You should be set to go.If this is not the right solution please post again.Thank You for choosing FixYa.
Sep 07, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
GAS GAUGE NEVER READS FULL AFTER FILL UP. IS THIS SOMETHING I CAN DO ON MY OWN TO FIX.
There is, but it is not worth the work involved. Purchase a replacement gage and install it. This of course involves removing the fuel tank. Frankly, I'd rather go to the dentist. Drain the fuel, mash your fingers, get dirt in your eyes, risk dangerous explosions, waste an otherwise beautiful Saturday and possibly the weekend, risk damaged components and for what? So it will read full instead of almost full?
Expect to pay $40.00 or more for the device. Tools you will need? Pliers, screw driver, floor jack, bumper jack (what ever your car uses to change a tire), and jack stands. Never get under a car supported only by the jack you use to change the tire. Hammer, mallet, sockets, handles and extensions - preferably 'explosion proof' you you have access, and of course a nice dry, well ventilated place to work. You should run your tank as low as you can so you will not have to handle a large quantity of fuel. You will need buckets. You may need to repair wires and hoses - be prepared to run to the parts store for these incidentals. Loosen the filler tube and pry it off of the tank - try not to damage it. Catch the fuel. Put the floor jack under the tank with a large piece of plywood on top of the lift area. Jack the wood into position firmly against the tank. Loosen and remove the straps. Slowly lower the tank - watch for spilling fuel. Once the tank is on the ground, disconnect the hoses and wires on the top of the tank - pull the tank out. Remove the inspection cover which is also the access to the sender and unit and probably the fuel pump. Since you are doing all this stuff, you may want to change the pump and filter, if any. You will need at least a foot of distance under your wheels so you can get up under the car to work on the top of the tank. Reverse the process of course to reinstall the tank.
I have worked on five tanks ... I will not do number six, I don't care the cost.
Good luck to you if you take this on.
Thanks for your question @ FixYa.com
Apr 09, 2011 | 2001 Ford Expedition
Someone put sugar in my 1997 plymouth voyager gas tank. How do I remove the gas tank to clean it ?
TO REMOVE FUEL TANK YOU FIRST RELIEF FUEL PRESSURE.THEN YOU RAISE THE VECHICLE AND SUPPORT ON JACK STANDS.THEN YOU DRAIN FUEL OUT OF FUEL TANK.YOU CAN GO TO ANY AUTO PARTS STORE BUY A SIPHON.DONT SIPHON GASOLINE WITH YOUR MOUTH.SWALLOWING GAS AND FUMES COULD BE FATAL.WHEN ALL FUEL OUT THE FUEL TANK.REMOVE THE FUEL FILLER.DISCONNECT THE ELECTRICAL WIRING TO FUEL TANK.THEN DISCONNECT ALL THE HOSES FROM THE FUEL TANK.PLACE A LARGE FLOOR JACK CENTER OF THE FUEL TANK.PLACE A PIECE PLY WOOD OVER FLOOR JACK LIFTING SADDLE TO KEEP FROM PUTTING A HOLE IN FUEL TANK.START RAISING FLOOR JACK UNTIL SADDLE TOUCH GAS TANK JUST ENOUGH TO HOLD TANK IN PLACE.THEN YOU REMOVE FUEL PUMP SUPPORT STRAP BOLTS DROP FUEL TANK DISCONNECT FUEL SUPPLY AND RETURN HOSES AND DISCONNECT FUEL VAPOR LINES FROM PRESSURE RELIEF ROLLOVER VALVE.THEN REMOVE TANK.IF HAVE TROUBLE REMOVING FILLER TUBE AT GAS TANK SPRAY WD40 AROUND WHERE FILLER TUBE GOES TO GAS TANK LOOSEN THE CLAMPS AND USE LARGE VISE GRIPS WORK FILLER TUBE HOSE AWAY FROM FUEL TANK SPRAY WD40 INTO IT SLIDE ON OFF.WHEN YOU GET FUEL TANK OFF USE A FUEL PUMP MODULE LOCK RING TOOL TURN LOCK RING COUNTERCLOCK WISE.IF YOU DONT HAVE THE FUEL PUMP LOCK RING TOOL.YOU CAN USE A HAMMER AND BRASS DRIFT OR A PLASTIC DRIFT DONT USE NO METAL DRIFTS OR PUNCH YOU WILL MAKE A SPARK AND HAVE EXPLOSION FROM GAS FUMES BE EXTRA CAREFUL.REPLACE FUEL PUMP SOCK AND FUEL SUPPLY LINES IF STOPPED UP AND REPLACE FUEL FILTER.PUT EVERY THING BACK IN VISA VERSA.IF ALL GOES WELL. GO TO AUTO PARTS STORE BUY A GAS CAP WITH A LOCK SO WHO EVER PUT SUGAR IN YOUR GAS WONT BE ABLE TO TRY IT AGAIN GOOD LUCK.
Oct 23, 2010 | 1997 Plymouth Grand Voyager
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
How do i replace the tube in my projection tv
Good Day, pinky91,
Replacing a tube is easy, remove cabinet front and back, to get to top of crt's & cables, unplug all cables to defective tube, yoke, convergence cables, anode, crt socket.
The biggest concern should be installing the new tube. Ater replacing the tube it must aligned, not easy. It takes an experienced Tech about 2 to 2.5 hours to perform this repair.
Good Luck, big IRISH. P.S. I would recommend to have a professional to perform this.
Jul 15, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
