F20 is a No Water Detect error. It
is an indication that you either have no water coming into the washer,
or very little water at all. If the pressure switch has not tripped
after 6 minutes, the error code is displayed. This can be a potential
problem with the following:
* If you have no water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
* If you have water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the link for instructions: Duet_Service_F20_error
Hope this helps and just keep in mind that your feedback is important
and I'll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa.
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Hello leah_mcmunn - the error code E-20 indicates that the water doesn't drain. This could be caused by either the drain hose is kinked or your household drain is clogged. If the drain pump is making a humming noise, check the restriction in the drain line. If not, then you might need to contact a professional to possibly replace the pump.
