Convergence On Panasonic PT-47WX54j
I need the code to pull up the cross-hatch to adjust the convergence in the 'serviceman ' (not the customer ) mode.Also need the exit code to save the adjustments. thanks Panasonic Projection TV PT-47WX53G
    Novelist:
    Champion:
  • 203 Answers
Though i answered this exact question tonight, but maby it didnt post, sorry...heres the instructions.
To enter the service menu follow the directions below:
1) Go into the menu and select cable mode
2) Set sleep timer to 30
3) Exit menu and change chanel to 124
4) press and hold volume down button ON THE FRONT OF THE TV
5) A red "chk" should appear in the top right coner
Once you have the red CHK i think you press action to get the menu up, then chose convergence.
RTUNE- changes colors
MUTE-makes the cursor blink and not blink (when its blinking you can move it from point to point, when it stops blinking you can adjust that point)
"7" - saves the changes you have made
When you are done to exit the service menu follow the directions below:
Press ACTION and POWER buttons together on the FRONT of the set
the tv should the reset itself and turn itself off and back on.
Also if you have a convergence problem and have not repaired the circuit then going into this menu and trying to do adjustments can cause major problems in the dcu so if you have not repaired the circuit DO NOT go into this mode. you must first fix the circuit, and if you dont know how to fix it then you should call a repair man. You can cause major problems in the menu that are not fixable once they have been done.
Let me know if you need more info!
Posted on Sep 25, 2008
My tv has a arching green tint towards the bottom of the screen that also gives off a double image. I have a Panasonic hdtv 47 in screen model no: PT-47wx54j
Convergence problems. If they can't be fixed from the setting on the menu then the convergence board's IC's are faulty and must be replaced. This is a job for someone who has some electronics experience.
Aug 09, 2010 | Panasonic PT-47X54 47" Rear Projection...
I have a panasonic pt-47wx54j and it is double imaging. convergence board? suggestion?
Install a convergence repair kit. You can get the repair kit for your model at www.tvrepairworld.com the kits contain the parts and the Cd with instructions.
Jan 15, 2010 | Televison & Video
Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Did you do a repair on the convergence circuit? If so it would be ok to do an adjustment in the service menue. But if you have a problem in the conergence circuit and you dont repair it first, making adjustments in the service menue can do damage to the DCU and cause you major problem in the future. If you have already repaired the convergence circuit then let me know and i will get you the codes.
Tim nolan
experttv@comcast.net
Sep 24, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic TV
thats the error code for convergence. You will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link with free instalation instructions.
Sep 04, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX54J shut off - LED blinks 3x
Your convergence ICs need to be changed. 3 Blinks is a convergence error. I can post a link where you can get new ICs and they include free instructions with pictures so you can do the repair yourself, they also offer instant messaging with a tech while your doing the repair thats a free service when you but their replacement parts. Let me know if you would like the link.
Apr 04, 2008 | Televison & Video
Televison & Video Logo
579 people viewed this question
Top Televison & Video Experts
Electro Med Services...
