Question about Philips Magnavox 51MP392H Rear Projection Television
Left top and right top of screen curled, bottom middle of screen has a hump to it
One day i turned my tv on and the colors were out of whack so i manually adjusted the convergence and the colors are fine however when watching a program like a baseball game the score that appears on the top of the screen is curled at each end and also any words that may be at the bottom middle of screen are raised up like a hump. Any ideas i mean tv is watchable however looks weird watching sometimes.
  • 1 more comment
  • pebblestorm Sep 25, 2008
    Thanks Tim for the info. yes i can solder and use a meter how delicate is this procedure and how do i not shock myself in the process. I do have some bench assembly experience but has been awhile though.
  • pebblestorm Sep 28, 2008
    Tim,
    According to the guest comment he may or may not have the same problem as me he has replaced both of the ic's and is now having another problem. could there be something else wrong if it is not those chips. curious.....
  • pebblestorm Nov 11, 2008
    Hi Tim sorry for lack of response in what is going on finally got set apart to some degree trying to find the ic's here is 2 pics is there an easy way of any kind to get at these things the right way if im making sense also when i do get the parts best way to desolder the old ones and resolder the new ones.
I HAVE REPLACED BOTH ( STK392-110 ) AND NOT ANY BETTER STILL CURVED PICTURE NOW IT WONT LET ME ADJUST THE CONVERGENCE (( WHAT CAN BE WRONG ))????..THANKSS..
Posted on Sep 26, 2008
    Novelist:
    Champion:
  • 203 Answers
Yes you need to repair the convergence circuit. If you know how to solder and use a meter this can be fixed easily by yourself. If you call a repairman to do it, it will run you $300-$500 depending on your area. Let me know if you can use a meter and solder and we can move forward with repairing you set.
Tim nolan
Posted on Sep 25, 2008
  • experttv
    experttv Sep 25, 2008
    You dont have to worry to much about shocking yourself in this one as long as its unpluged and you stay away from the power supply. In order to fix this one you will need to replace both STK392-110's and any open resistors there by them. IF you have trouble finding the burnt resistors (if there are any) you can post a picture of the circuit boards and i will show you where they are.
  • experttv
    experttv Sep 29, 2008
    There are a few more things that can cause this problem. You need to check the resistors that are infront of the stk's If you are in the back of the set looking in, the resistors im talking about are to left and in front of the stk's kinda in the corner of the circuit board. If you post a picture of the board I will circle what i need you to check.
    Thank
    Tim
Mitsubishi LT46246 screen darkens from middle to left side and then ghosts on left side. If I whack the top of the TV it corrects to normal color. Can you tell me what might be causing this?
May be loose or damaged board connecting cables or connecting cables to the panel. Sometimes when these cables are not properly seated, over time they will deteriorate & need replaced or reseated.
Jun 28, 2014 | Mitsubishi Televison & Video
We have just installed a rainmaster tap timer RM1100 and have lost the instructions
C curved arrow button ( middle left ) SELECTS TIME, DURATION, DAYS, START & also SAVES SETTINGS
RIGHT ARROW button ( MIDDLE RIGHT ) SELECTS Day or hours or minutes to be changed
MINUS button ( top left ) changes backwards values of: days, hours, minutes
PLUS button ( top right ) changes forwards values of: days, hours, minutes
HAND button ( bottom ) manual turn on & turn off water flow through timer.
Aug 05, 2013 | Motorcycles
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
Multi colored strip running thru tv
I'm affraid to say that your screen has got a PDP/LCD fault. Just like a tube going on a TV. This is a fault which is beyond economical repair
May 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
Arc or hump on bottom left of tv and color is faded bad.
Your convergence Ic's have gone bad. Most likely a few small resistors with them. It's really not a job you should try and takle if you haven't done it before. Not a major deal for a svc co.
Feb 05, 2009 | Philips 60PP9202 60" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
