Question about Kenwood Car Audio & Video
I am trying to install a kdc-217 and I have the wire harness but the car has another part that looks like it's supposed to plug into something there are no loose wires to connect the wire harness to
  • aryana32 Sep 25, 2008
    So I can just take it off and connect the wires like that??
    Problem Solver:
  • 13 Answers
It might just be the factory harness that has been left in there, i had that happen with my cav
Posted on Sep 25, 2008
  • cheyner Oct 07, 2008
    if it looks pretty much the same as the plug for your deck then yeah no problems
Kenwood kdc-x399 troubleshooting
Check Kenwood wiring color code and function against vehicle harness color code and function. They are not always the same.
Aug 03, 2016 | Kenwood Car Audio & Video
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I had an amplifier and sub installed using the factory cd player and it worked fine. then i replaced the cd player and now the sub and amp are not working but the new headunit works fine. the amp is...
if the wire ur talking bout suppose to be connected then ur radio shouldn't *** on ..the wire suppose to connect to the back of the radio where a screw goes, its a ground wire...hop i was of help.
Jul 12, 2009 | Kenwood KDC-MP435U CD Player
What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP228 CD Player
Installing aftermarket radio in 2004 ford focus
the 3rd plug is for volume etc on the sering wheel
Jan 09, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
No sound
it sounds like you have a short on two of your speaker wires just connecy front speakers and try then rear then left then right to prove which one or ones
chris
Oct 29, 2007 | Kenwood KDC-217 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
