Samsung SYNCMASTER 570DXN MONITOR 58.1 X 37.3 X 17.5 126.1 LBS. 57 5000:1  8M Logo
Anonymous Posted on Oct 31, 2011
Samsung led monitor blinks on pc but only on desktop picture
If i click on documents tab picture stays on but if i put desktop picture on it blinks on and off continuosly
pravin bhavsar
Level 2:
  • Expert 348 Answers
  • Posted on Nov 07, 2011
pravin bhavsar
Expert
Level 2:
Answers
348
Questions
Helped
106326
Points
813
Presss four buttons on the control panel simultaneusly and keep pressed untill
unlocked message will appear when unlocked message will appear your problem will be solved .all procedures will carry in power on condition
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
1helpful
Menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
No picture, power led blinking, ticking sound in an LG 702b monitor
our both the monitor having same diffect.
Out put transistor will be short.
replace it and check the other parts in the horizontal section
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
1helpful
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
2answers
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
VPR Matrix 226R-Blank screen when powered up,LED in front blinks
Not a power problem. Could a memory problem try changing the memory (DDR SDRAM), see if monitor comes on and if the system does a POST (power on self test) That should indacate any further problems if any.
Hi there. I purchased a Samsung 19inch monitor today to hook up to my laptop. I am have the desk top picture up on the screen but no icons and i am still having to work off my laptop. I have clicked on...
Right-click on your desktop, choose PROPERTIES, a windows pops up.
click on the DESKTOP pane, click on the CUTOMIZE DESKTOP... button. on the GENERAL tab you will DESKTOP ICONS, Check the icons you find there
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
