Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor flickers when you click a hyperlink - Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
    Scholar:
  • 91 Answers
It sound like the video refresh rate is to low. To change the video refresh rate consult your monitors user guide and if you are running WIN XP operating system you can try the following:
How to Change the Screen Refresh Rate of Your Monitor
loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
Let me know if this helps and thank you, Binary Bob
Posted on Dec 08, 2008
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
Monitor flickering
click on start then help and support. after it opened,simpy in the search box, type "monitor flicker" you should recieve an information in the search results then click on it,you will get the help needed
Jun 10, 2010 | Samsung T220HD LCD Monitor
The monitor flickers
Right click on "Desktop" screen, select "Personalize", click to open "Display Settings", ("highlight") and make all necessary changes to stop the flickering , and improve the visual.
Jan 20, 2010 | Toshiba Satellite Pro L300 Notebook
PowerPoint Hyperlink Removal
Hi benhen1997
Place your cursor on the hyperlink, and rightclick. You get a popupmenu.
Left Click on th e"Remove hyperlink"
That is all you have to do.
Cheers
luciana44
Jun 24, 2009 | Microsoft PowerPoint 2000 for PC
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
I WANT TO CREATE A DATABASE FOR PDF FILES USING MICROSOFT ACCESS
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Mar 24, 2009 | Microsoft Access 2003 for PC
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Hyperlink function in ms access
To Create a Hyperlink Field:
Display the table in Design view, create a new field to store the hyperlinks, click the new hyperlink field's Data Type box, click the list arrow, select Hyperlink, and save the table.
To Insert a Hyperlink:
Select the hyperlink field and then click the Insert Hyperlink button on the toolbar or select Insert , Hyperlink from the menu. Either select a file you want (use the Browse button to help you locate the file) or type a Web address for the hyperlink's destination and click OK.
To edit a Hyperlink: Right-click the hyperlink and select Hyperlink , Edit Hyperlink from the shortcut menu.
Is this enough?
Dec 21, 2007 | Microsoft Office Access 2003 (077-02871)...
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
126 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
