Need to fix my circuit board on a LCD
My 46" LCD Samsung 1080p will power on but I do not get a picture. Had slight electrical surge. Opened the set and notice that the rectifier DP806 was fried. Where can I get a replacement one. also some of the sodering appears to have been broken but I'm not sure because I do not have a diagram. Any idea's where I can find one? Thank you!
  • spikee1956 Sep 25, 2008
    my le37s73db does the same it powers up the standby light flashes slowly but flashes faster when the remote is activated it was fourteen months old when this happened did samsung care NO!!!
SOURCE: The 'antenna in' cable hook up spins
I was a Tech for Vizio for 3 months I Have a couple board Brand new one of them in label Samung dtvs205ch201a 070705 IDT-LF
Let me know if that s what you looking for
my email is dessables@gmail.com
Posted on Mar 01, 2009
  • 10865 Answers
SOURCE: I can't find the owner's/TV manual for Sharp AQUOS
http://www.sharpusa.com/files/tel_man_LC46D43U.pdf
Posted on Jun 04, 2009
  • 4 Answers
SOURCE: I bought my Sharp Aquos 46 LCD 1080p 60hz as the
dynamic is a set calibration , u want to go to user then u can set it.
Posted on Jul 22, 2009
SOURCE: Same "clicking" problem with 46" Samsung LCD...does not turn on.
With any luck you will have the same problem asa the rest of us : blown power board capaciters , remove the rear cover {20 screws} look in the middle of the back of the set with the cover {5 screws} removed from the power supply . Now look to the upper right cornerof the board in the middle of the tv there may be 1 or several capaciters leaking from the X shape on the top , this be be your problem match up replacements but source units that have a higher max voltage than 10volts 7 get them soldered into the board . I repaired mine that failed at 16 months for $4 in parts & it took longer to remove the screws than it did to affect the repair. If you are not conifident about soldering on your $2000 tv then take the board to someone for the job to be done , I would not advise this as a first soldering job , good luck I can't belive how common this is Samsung needs to step up ......
Posted on Sep 17, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Hi my led tv UE46D500 has no picture only sound.unplug for few hours and the picture comes back.now I have this problem every day sometimes I got the picture and sumtime no picture whole day. Help pls
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Jan 10, 2017 | Samsung UE46D5000 116.8 cm 46" 1080p...
Need advice on color issue with Samsung UN46EH6000F TV
The TCON board or the LCD panel is Faulty , Can confirm by replacing TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Samsung UN46EH6000FXZA 46 1080p 240Hz LED...
Television Samsung Model UN46EH5000F
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Dec 23, 2016 | Samsung Un46eh5000fxza un46eh5000 46 1080p...
Samsung 46 Inches LCD TV Model#LN46C630 Black Screen with Sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Samsung LN46C630 TV
How do I fix my 2 year old 46" SAMSUNG UN46EH5000FXZA. I have a BLACK SCREEN and it had sound when it went out.
Oct 29, 2016 | Samsung Un46eh5000fxza un46eh5000 46 1080p...
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Sep 30, 2015 | Philips 46PFL5706 - 46" LCD TV -...
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Aug 05, 2012 | Samsung LN46C650 46 Series 6 LCD 1080p...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
