Question about Compaq Computers & Internet
The rihgt click from the touchpad doesn't click
  • 781 Answers
How old is your laptop?
1. try having your laptop cleaned up.
2. try to reinstall the drivers from this device (check the laptop manufacturer for drivers before you uninstall the drivers from device manager.
3. check bios configuration.
4. buy a usb mouse that you can use instead of the touchpad.
Posted on Sep 25, 2008
Left click doesn't work
The touchpad unit may need to be replaced. you didn't specify the model, but most of the touchpads can be replaced without too much work.
Mar 23, 2013 | Computers & Internet
Disable a touchpad that doesn't appear anywhere in system
Go to device manager in windows control panel admin tools and look under human interface devices. You can right click on it and disable it there.
Jan 15, 2013 | Toshiba Satellite C655d-s5518 Amd-e-300...
Touchpad does not work
Locate the function key (F1 to F12) that has the touchpad sign. This is often a rectangle with two smaller rectangles below it representing the touchpad and its two buttons.
Press FN + The touchpad button
If this doesn\'t work, then you need to do the following:
  • Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
  • Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
    If no go, then update your touchpad driver by going to Computer (right click), Manage > device manager.
    Look for the touchpad driver and update. If you want to avoid these kinds of problem in the future, then install radarsync to automate the updating mechanism of your computer. It\'s automatic and you don\'t need to do anything.
    I hope this helps!
    Carlo
  • Dec 17, 2012 | Toshiba Computers & Internet
    Hp 630 touchpad not working -pointer moves but doesn't click
    Double click on pad surface. Buttons could be faulty. Check mousepad settings. Install drivers
    Dec 08, 2012 | HP Pavilion ZD8110US Notebook
    Unlock laptop mouse
    Examine your "Function"/"F" keys and look for a touchpad icon.
    If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad.
    Move on to Step 2 if your laptop doesn't support this feature.
    Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button.
    Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
    Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable."
    Your touchpad is now unlocked.
    hope this helps
    Oct 25, 2012 | Dell VOSTRO 3350
    My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
    Click "Start." Click "Control Panel" in the right panel.
    Click "Accessibility Options."
    Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
    Click "OK" to unlock the keyboard, including the keypad.
    Unlock Touchpad
    Click "Start," then "Control Panel."
    Click "hardware and Sound," then "Mouse."
    Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
    hope this helps
    Aug 17, 2012 | Synaptics PS/2 Port TouchPad
    Unlock the mouse in dell inspiron m5030
    1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Dell Inspiron M5030 Laptop
    Toshiba Laptop left click stopped wokring?
  • Feb 06, 2012 | Toshiba Satellite L505-S5966 Notebook
    The left button at the bottom of my touch pad has a problem. the click is delayed, i have got to hold the click for longer so that the click may occur
    @inam_khan_10
    Try the following:
    1. If your computer is running on Windows, try to boot into Safe Mode (you need to press F8 continuously upon boot-up then choose Safe Mode) and check if your Touchpad left clicker. If it works ok, then a software problem is causing the Touchpad to delay like that. Try reading this guide to solve it.
    2. If Step 1 above doesn't work, try to use a compressed can of air to clean the Touchpad clicker and see if same issue occurs.
    If still no go, this is a sign that your Touchpad is already wearing out and it needs to be replaced.
    Good luck.
    Sep 05, 2011 | Computers & Internet
    My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
    Hi!
    If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
    If it still not work, please check if the touchpad drivers are installed on you netbook.
    To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
    Now, under mice and other pointing devices you should find your touchpad.
    If the touchpad is not listed in device manager, drivers for it have to be installed.
    Drivers for your netbook's hardware are on the acer support page.
    Hope it helped,
    Bogdan
    Aug 28, 2011 | Computers & Internet
    Computers & Internet Logo
    24 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
