Question about Whirlpool Kitchen Ranges
Electronic board burn after plug in the top of the oven 110 volt accessorie. what appen whit the board and what is the amperage I have in this plug? thank you Dean 418 609 0870 deanverreault@hotmail.com Do you know the price for the electronic board wirpool werp3101ss 789/10082150 watmw
4 Suggested Answers
informatica
  • 1114 Answers
SOURCE: Indesit oven markings have been wiped off
Your model number can usually be found on a white or silver rating plate located somewhere on the product, usually the base, rear. Instruction books can be downloaded from the following link: http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Jul 28, 2007
fridgetech
  • 473 Answers
SOURCE: Hotpoint gas oven
Most common problem is the ignitor.
Posted on Jul 14, 2008
allbrands
  • 600 Answers
SOURCE: the oven and broiler will
Hello, Thank You for using FixYa. I will be helping you today.So at the terminal block you should have 120v from L1 to ground and 120v L2 to ground and about 240 from L1 to L2. So left to center 120 right to center 120 and left and right together 240 if its not its your house wiring.
Thank You and please rate my answer if it was helpful..
Posted on Jun 15, 2011
What would cause the broiler element to override the baking element? My oven has lost its mind. It doesn't matter what setting I use, The broil element takes over and burns everything. Please help.
Not 100% sure but my guess. Most electric ovens usually bake with both elements on. The bake element(bottom) is usually on at full power with 240 volts to it. The broil element(top) is usually on at 1/2 power 120 volts to help even out the temperature. My guess is your bottom element is not coming on at all either because it is burned out or something in the control system. So what is happening is the oven is trying to heat to the set temp with only the top element keeping it on much longer than it normally should be on and burning everything. Now if you set the oven for bake and the top is on red hot, you have a control system problem something like a bad selector switch or main control board if the oven has a electronic control.
Apr 10, 2015 | Ovens
How do I make a 220 volt outlet where there is only 110?
what you need too find out is what is the amperage of the 220 oven and may have to run the proper size wire rated for the amperage back to electric panel to the proper size breaker the info should be on the name plate
May 26, 2013 | Leviton 15A Decora Electrical Outlet Light...
My whirlpool stove RF365PXMQ0 will not heat up the top burners or the oven. What could be wrong?
need to get a volt meter and check the incoming power( at the plug ) and make sure you have 240 volts!! it only takes 110 volts to run the top burners, and takes 240 volts to run the oven!!
Feb 10, 2012 | Whirlpool Ovens
Stove top is working but neither the broiler nor bake is working. Cannot bale anything but the stove top cookers are fine. What could be the problem
Stoves are wired for 220 volt, but the range top will operate on 110 volt so your Breaker should be a single 220 volt breaker but can be achieved using two 110 volt breakers if one of the breakers blow the range top may still operate but the oven will not. So my suggestion is to Check your breakers to see if you are operating on two 110 volt breakers and one is possibly tripped.
Thumbs Up if Helpful, Feedback is Appreciated!!!
Jun 18, 2011 | Frigidaire FEB27S5A Electric Single Oven
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 | Ovens
Stove and broiler does not heat up. Haven't been able to cook
first you need to check your breaker, turn it off and back on,, if that doesnt work you need to check the volts in the plug and where the plug screws on to the stove, it should have 220 volts or 110 per side,, if it has the 220 volts(if it has the eletronic control pad) the board could be bad, (if it has the knob thermostat ) it could be the thermostat,, is the cook top working? if it is it sounds like a power issue, 110volts runs the top the other 110 volts runs the oven
Jan 19, 2011 | Microwave Ovens
Change from 110 to 220 volts transformer
It sounds like the replacement 220 volt transformer is putting out too much power, as replacing a 110 volt transformer with a 220 volt one should have no effect on other components, as the output voltage and amperage should be the same as the original one.
Apr 05, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
My conveyor is not moving on my pizza oven any suggestions?? its a middleby marshall q360
These little motors are controlled by a rheostat for speed control, or electronic speed control. Follow wire from motor to control and check. Also; is chain on?
Jul 06, 2009 | Ovens
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
