Question about Durabrand DWT1905 TV
Durabrand DTV 1907
When I turn on my television, it starts to make a "cracking" sound, and the picture jerks around. Does anybody know what this means? Can it be fixed?
  • djsillito Sep 25, 2008
    Last night along with all the other "cracking" and screen jerking, It also just started turning itself of every few minutes. Which is even more annoying. Does that still mean its the High Voltage Circuit? Thanks for your help!
  • 927 Answers
Good Day;
It sounds like you have a problem in the High Voltage Circuit. Yes, it can be fixed, call your local Authorized Service Center and have them give an estimate.
Good Luck, big IRISH.
Posted on Sep 25, 2008
  • MICHAEL MULLINS Sep 26, 2008
    Good Day;
    That is what I would suspect to happen next. Your answer is yes.
    Again good Luck, big IRISH.
Tv turning off
check for loose solder joints
Jan 26, 2009 | Durabrand DWT1905 TV
Don't understand about digital and analog
Hi, The TV has an analog tuner only and so is not DTV ready. You will require a seperate set top box to receive digital programs with it. If you have brought the set recently it should have had an appropriate warning label on it. If not ,you may have some come back with the store which sold it.(depends on the country where purchased)
Jan 02, 2009 | Durabrand DWT1905 TV
Won't receive digital signal
Call the customer service number on the set.
Oct 29, 2008 | Durabrand DWT1905 TV
Up to channel 15
using your remote press menu and press auto program
Sep 26, 2008 | Durabrand DWT1905 TV
Durabrand tv codes
It might help to find out what company made your Durabrand(walmart) tv. Try the codes listed under their name. Model numbers starting with DTV or DU are Orion, BH Haier, IWT or DWT Funai.
May 09, 2008 | Televison & Video
No picture or sound
Last time one of my durabrands did this I unplugged it for like 10 mins and gave it a nice kick to the side and it worked fine again. I know it sounds crazy but dont kick it too hard like dont crack plastic. I have also done this to oversurged CRT monitors
Apr 03, 2008 | Durabrand DWT1905 TV
Too much color picture all black
Sounds like a bad cap in the Y circuit.If it flashes when you tap it. You may find a cold solder joint on the yoke board or bottom of main pwb.Let me know - edcarson
Feb 12, 2008 | Durabrand DWT1905 TV
DURABRAND TV 1907
use a sky remote you can tune it to your TV all buttons will be in the wrong place but they are there.
Nov 01, 2007 | Durabrand DU1901 TV
Mintek 26 lcd hdtv, model DTV 265D
Have Mintek DTV-265-D that is frozen. Any suggestion to correct this problem?
Oct 20, 2007 | Mintek DTV-263 26 in. LCD Television
No Picture Sound OK
Sounds like maybe some bad solder connections in the deflection area, If I remember these monsters correctly they are hard to dissassemble with lots of wires, the culprit is probably a solder crack around the horizontal section or the power supply for the horizontal. Might require a technician for service, if you attempt yourself, use lots of masking tape to label your wires.
Jul 08, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Durabrand DWT1905 TV Logo
96 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
