Question about Whirlpool Refrigerators
Refrigerator odor We have an estate top and bottom refrigerator made by whirlpool. Starting a few days ago, we had a bad smell in the kitchen. FYI we were without power for 4 days after hurricane ike. Last night, I cleaned out the refrigerator and freezer from top to bottom. A bad odor still comes out from the bottom/back part of the time (I think when the frig is running). The smell stops when I unplug the frig. It is better today but not solved. I also took off the cover on the back/bottom but I don't see anything. Also, we have had a couple of mice lately. I am stumped.
  • 409 Answers
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
Posted on Sep 25, 2008
It has a bad smell coming out of motor area
Hello friend, thank you for your post!
I understand that you are having an odor issue with your Frigidaire refrigerator. Usually odors can stem from spills or food within the refrigerator. You can clean the interior with warm soapy water or warm water and baking soda.
Another home remedy is using a pan of charcoal (do not use the one that contains lighter fluid) or kitty litter inside the bottom of the refrigerator and that can help clear out an odors within your refrigerator. I hope this has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
Chemical smell in kitchen. is it coming from my brand new refrigerator?
the odors are normal for some new refrigerators,its due to the type of plastic used,let it cool and put coffee inside both compartments or baking soda as these 2 items will remove odors,after the odors gone continue to keep a box of baking soda in each compartment to control all food or plastic odors,this should help remove your odor problem
Feb 12, 2013 | Whirlpool Refrigerators
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Odor when starting cycle
Check your water softener(If so equipped). This can cause foul odors in the water supply if not properly balanced or maintained. Good luck!
Sep 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Refrigerators Logo
323 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
