SOURCE: TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
SOURCE: Zenith D60WLCD
Long story short: The blue fog problse is the light engine. Specificaly, the filter for the blue LCD gets to hot and over time starts to burn up and disinigrate. (I just tore my set apart thinking maybe it was the blue panel and found this was indeed the culprit for this problem). As far as a solution? You will either need to replace the light engine (expensive) or replace the light filter which means tearing the thing completely apart. then there is the problem of where to get a replacement filter. Does ANYONE know where? As far as the lamp goes, might be time to replace it. You might be better off just getting rid of that TV and get a new one.
SOURCE: My lamp inicator flashes red
Okay this tells me something is getting hot and forced shutdown so I would check and see if fans are obstucted, and there RPMs are up to par.
But when in doubt always call the manufacture as they know to whom to take it to for a repair.
Something is causeing this to turn off and its mostlikly the heat,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: MY ZENITH D60WLCD PICTURE IS VERY DIM. i HAVE
Have you adjusted the brightness settings or any other settings to change the picture?
