Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blue Flickering Screen - Which Repair Kit?
I have the blue flickering screen issue... which after reading other posts... seems to be a swollen capacitor issue.
wd-52525
Can someone explain to me which repair kit I would need to purchase from http://servicemanuals.vstore.ca/index.php/cName/repair-kits
They list 3 kits:
V26 DLP Signal PCB Repair Kit
Mitsubishi V26 DLP power PWB Repair Kit
V26 DLP FMT PWB repair Kit
Which would I need to get?
(Also, im told that they have a service manual with the kit correct?)
Thanks
  • redgst Sep 25, 2008
    Yeah, I dont know which one it is.
    I still have a blue screen, and I can actually see the TV Menu (although its very shrunk and flickering in the middle of the screen).
    Also, I've noticed 2 other things... once the menu options dissappear, the screen is all blue, with some white hortizonal sections in the middle (kinda looks like a white sunrise over the horizon thing)
    One other thing... when the tv initially starts up, and before it goes blue, it starts off as a dark screen with some white show going across the middle.
    I guess worst case scenario is that I go with one, and get the service manual, and if im wrong, just buy the other kit? I do kinda hope to get it right the first time though, cause i hate watching tv on my old tube!
    Any more help appreciated! Thanks!
  • 58 Answers
2 swollen capacitors on the power supply (first board you can see on the chassis when you start to dissassemble) big caps... 3300 uf... 16v i think. these caps can also induce a 3.4 code (lamp error) and all around **** picture. fmt failures can range from black and white checkerboard pattern on the screen to wavy lines over the picture and also the blinking green light. DM failures I've seen include the blinking green light , wavy lines, and weird digital failures like horizontal bars green blocks or the picture being cut in odd places.
also when you hear that the failure is caused by the capacitors (blinking green light mainly) the culprit is not only the bulged caps. This is why you can change all the caps on the boards and still not have a working tv. its about 80 surface mount caps across both the fmt and dm. techs, look at your replacement boards and notice the darker print on the 47uf caps. good luck trying to change them it takes me about 3 hours to do both boards and about 45 dollars worh of caps.
Posted on Dec 30, 2008
  • Mitsubishi Master
  • 8,617 Answers
Yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Posted on Sep 25, 2008
Why is my Mitsubishi flat screen flickering green and blue
if it is starting to flicker green and blue that is a good sign that it could be going out. had a tv just like yours that started just flickering blue. about a month later it stopped working.
Jul 30, 2015 | Mitsubishi Televison & Video
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Blue screen problem
Persistent blue screen that results in Hard Drive dump? or Flickering Blue screen? Persistent: get a new hard drive if you have a friend to install it for you- not that hard to learn yourself, or buy a new computer. Flickering: try factory restoring it, make sure you back up your data from the boot menu first.
Jan 21, 2013 | Computers & Internet
Vizio start blue/yellow flickering screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 01, 2017 | Vizio VW42LF 42 in. LCD HDTV
BLUE AND YELLOW U-SHAPED IMAGE TOP OF SCREEN
U have convergence problems,it dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 57F500 57" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Blue flickering screen
What kind of motherboard/computer is it? Is the video onboard, PCI or AGP?
Aug 21, 2008 | Acer Aspire 5100 Notebook
Where do I get a PWB-signal 930B923002?
Try alldatadiy.com or acrobatfiles.com/mitsubishi or splodeman.com/Mitsubishi
Sep 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
434 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
