Question about HP Compaq Presario SR1220NX (PJ517AAR) PC Desktop
Bios password lock
I did full reformat on my compaq presario and installed windows  xp pro after installation i was prompted for password, i didn't remember password.. So i rebooted from bios  in F10,i reset what  i thought  was changing password but- not so.. Now i have the problem that windows will not even load .i just get a black screen with a blue square  inside it says," Power on password"  a picture of a key .. please can someone help... thanks
  • sambo029 Sep 25, 2008
    thanks 4 trying ,but it wont let me tipe in anything in the bios . Ive tried & tried but nothing ... So i came up with a salution... !! ive taken the bios battery out from within the computer- i left it out for about 2 ohwers in order 4 it to loose bios memory charge, wich aloud it to reset , and when i put it back in it worked problem solved .!!!!!! But i still have the problem of not being able to log on to windows due to forgotten the password i verry much appreciate ure time once again thank you ...!
  • sambo029 Sep 26, 2008
    Well Ardmax there"s no doubt about you. The advice certainly helped me, i  rebooted my computer loaded  cd rom in the computer - and ran the repair prog from f8. etc ... My computer is running once again ..i took you"re advice i didn"t give up and now its working just fine..fully reformated good as new even better  thanks once again ...!!!!!!!!!! lol...!!!!!!!!!!!!!!!!!!!!!.....!!!!yeh ....
    Scholar:
  • 155 Answers
It is my understing that Windows XP was asking for a password and you chenge the one in the BIOS
Now the BIOS is asking for the password that you put when you say you resetted.
Please enter the password that you put in the BIOS and let me know if you are going to get a different screen other then the blue square with the picture of a key.
Best regards
Posted on Sep 25, 2008
  • Massimo Ardito
    Massimo Ardito Sep 26, 2008
    mmm.... you did the right thing with the BIOS but why do you want to give up so easy on the XP password?
    Do you really want to install everything?
    First I suggest you try to login as Administrator instead that you, I hope you didn't setup also an administrator password and I hope that if you did you didn-'t forget that one as well.
    Second if the Administrator login failed you have other options:
    1 - Follow these instructions http://pubs.logicalexpressions.com/pub00...
    2 - You can boot your computer using a bootable OS like Knoppix, recover all your documents and then reinstall Windows (Takes time)
    3 - Why don't you try the free version of this recovery tool (free if can afford to wait 72 hours) http://www.loginrecovery.com/
    Good luck
    PS let me know how it goes.
HOW TO BREAK ADMINISTRATOR PASSWORD TO Compaq Presario CQ57-339WM Notebook PC
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • There is a free boot CD called Hirens. This one command prompt only. http://www.hirensbootcd.org/
Oct 21, 2012 | Computers & Internet
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
I have reformatted my presario f700 laptop (compaq) from windows vista home premium to windows xp professional and after reformatted, a problem occur regarding audio device/sound is not functioning. please...
If your using a card take it out until you have XP installed.
Go into your bios and disable all your audio settings until you have XP installed.
Check and see if your audio is even compatible with XP.
Disconnect the any external devices that are connected to the audio input until XP is installed.
Nov 05, 2009 | HP Compaq Presario F500 F700 and G6000...
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Can't reinstall windows xp
hmmm its seems your HDD is of SATA interface and XP is not able to detect the HDD interface. you can solve this problem by making SATA Disabled in BIOS setup.
Try to make disabled SATA from BIOS, and then make install.
If any problem... Ask me
Thanks
Iqbal
Apr 05, 2008 | HP Compaq Presario C304NR Notebook
I need drivers
You should'nt nead drivers to install XP Pro.
You just put the CD in the drive and switch on.
If it does'nt boot from the CD you go in to the bios and tell it to boot from CDRom first.
Mar 17, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario SR1220NX (PJ517AAR) PC Desktop Logo
193 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
