Question about NetGear PS105 Print Server
Printing problem with PS105
I Have a Dot Matrix printer installed and it was printing fine until the other day. its not printing anything at all. i can ping the printserver with a good response. i can even telnet into the print server and check the monitor status.
this is what the status read.
(P1) STATE: Printing
TYPE: Parallel
PRINTER STATUS : On-line
BYTES SERVICED: 0
Even i keep sending the print job the BYTES SERVICED remains 0
I also turned the printer of which changes the PRINTER STATUS to Off-line.
please advise whats wrong here.
cheers
4 Suggested Answers
pastorm
  • 98 Answers
SOURCE: print server
Check the port configurations on both XP machines. It should have the IP address of the print server connected to the plotter.
Posted on Aug 01, 2007
SOURCE: Netgear Wireless Print Server WGPS606 won't install correctly
I finally got my WGPS606 installed - unfortunately, it's just on one computer so far, but that computer is on the network and is not wired. Here are a few tips:
1. hold the reset button (little pinhole) until you see some action going on with the lights (I forget exactly what happened, but after a while there was a change) - this served to "reset" my WGPS606's IP Address, which I had changed during setup.
2. connect your computer to the server with an ethernet cable and type in http://192.168.0.102 (the default IP Address of the server)
3. login with the default username and password:
username: admin
password: password
4. once logged in, you will see all of the WGPS606's information. At that point, you should be able to change the IP Address of the server to what you want it to be, but I think you can proceed to run the setup on the installation CD (or the installation program from the WGPS606's Netgear website) and it should be recognized on the wireless network.
In my case, I want to mention that when the initial setup failed for me, I used the MAC address on the back of the server. After steps 1-4, my server was finally on the wireless network by the installation program, however, the MAC address was 1 digit off from what was on the server. The MAC address on the back of the server was the PHYSICAL MAC address, whereas the WIRELESS MAC address was one digit higher (last set of numbers. For instance, on the back of the server, the MAC address ended in ":01" and I found out that this was the physical MAC address. The wireless MAC address was exactly the same, except the last 2 digits were ":02."
Another thing to note was that after the server was recognized, it told me to reserve a specific IP Address other than what I had previously set - I didn't realize that it chose it for you. Anyway, just keep that in mind. After this, everything worked like a charm - well, I have yet to set up the other computers to connect to the server, but at least I have one!
Hope this helps!
Posted on Nov 21, 2008
SOURCE: connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Posted on Mar 30, 2009
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
Printer epson lx300 can't stop printing
You need to reset the board, all dot matrix have some kind of a chip set as well that mostly can be remove. Just make sure you are grounded, its a last resort that I normally do for dot matrix that can't seems to stop printing or the panel are always lights on.
Oct 04, 2010 | Epson LX-300 Matrix Printer
Printing quality is very poor
The print quality of dat matrix printers depends upon the printer ribbon. If the ribbon is old or worn out then the print will be very light. In this case replace the ribbon.
Dot matrix printers are very old technology and I suggest you get a Inkjet printer or a laser printer.
Dot matrix printers cannot match the print quality of Inkjet and laser printers.
Jun 04, 2010 | Office Equipment & Supplies
Epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Epson LX-300 Matrix Printer
Difference between dot matrix printer and laser printer
1. Dot matrix as the name suggests prints in small dots. The print out u get in railway tickets. 2. Laser printers are very speedy and have clear and sharp printing. There is no comparison b/w a laser printer and dot matrix. If dot matrix is 1st GEnaration than laser is atleast 10 generations ahead
Aug 20, 2009 | Absolute Software ComputraceComplete for...
LQ 590 POS
the driver for your printer is not installed correctly. please reinstall.
Sep 23, 2008 | Epson Dot Matrix LQ-590 Printer
NetGear PS105 Print Server Logo
54 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
