Question about Roper Kitchen Ranges
I live with an old Roper Pilotless Ignition Stove. It has three vertical dials on the front betwen the main ingition knobs to control the Clock, the start time and the cooking hours. When I cleaned the stove, I manipulated those dials. The oven will now not turn on. The stove and the broiler however work fine. I am worried that I may have adjusted the cooking hours and disabled the oven in some way. This has happened before according to the owner of the appliance. It is possible that the oven starter went bad, but the owner in convinced it is operator error...Help!
  • 750 Answers
Jkfiction
Hello, welcome to fixya ,
I understand the problem.
Do not let the owner, try to blame you.The problem is the landlord !
Most landlords say this to the renters and will never want to spend a nickel to fix or god forbid replace the range with a new one for 25 to 30 years.
What is the model # of the range.
Here is a report that I recently read.
You can tell him this was in n consumer report!
Repair or replace?
When to pull the plug on your old range
It nearly always makes sense to undertake simple do-it-yourself repairs.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your range is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
7 or more years old.
Thanks to better recycling programs, less than 10 percent
of a range you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 25, 2008
What buttons do I turn on my 25 yr old Kenmore stove to use the cleaning feature
I think that range had a mechanical clock. On it, you have to set the start and stop time (and push or pull the knob(s) to activate it), close the lock lever, and set the temperature and function dial(s) to self-clean. Unfortunately, if your clock isn't working (which is a common failure on stoves this old), you won't be able to run the self-clean cycle.
Sep 14, 2014 | Kenmore Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
Replaced the old element in the stove now the stove wont turn on
Check the wires going to the broiler and see if your getting power there.
Oct 03, 2009 | General Electric Stove/Oven/Range Chrome...
I have a daughter with a four year old son. They live in an apartment with a pilotless gas stove. I am afraid at his age and curiousity he will turn on the gas and cause a buildup of gas which could cause...
Sorry to say there is no safty onthe stove. If you would like pull the handles off. They just pull straite to you. That is what I did with my son.
Good Luck and Please rate fixya!
Mar 02, 2009 | Tappan MGF500PBW Gas Kitchen Range
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Kitchen Ranges Logo
142 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
