Question about GE Heating & Cooling
Water is dripping on the floor not going into drip pan at bottom of coils on inside unit could coils be dirty
    Scholar:
  • 121 Answers
Yes coils could be dirty, but your drain is clogged. To clean the drain cut the pvc line and blow the drain line out. You can put bleach in the drain pan every 6 months to keep it clean.
Posted on Sep 27, 2008
Air Handler V coil drip into Plenum
dirty coil allowing condensate to form on surfuce of coil then dripping into plenum or defective drain pan.
Apr 08, 2014 | Bryant Heating & Cooling
Summer rite window air conditioner
if its driping on the floor then yeah a pan is good all aircons have a drain cause they create water of the coil
Jun 29, 2013 | Heating & Cooling
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
My portable a/c continues to leak water from the bottom when in use. I have a hose attached to the spout in the back, but it still leaves a puddle and almost nothing drains out the back. It's a sunbeam...
It sound like the coil inside could be dirty. I have had the same problem with air handlers, when the coil is dirty or the filter is dirty it creates a back pressure and causes the condensation to drip off away from the condensation pan. Try accessing the coil on the inside see if it is dirty, if it is clean it lightly with soapy water and a brush and be carefull not to bend the fins on the coil. If it is clean double check the condensation hose and inlet for the hose for foreign matter.
Aug 12, 2009 | Sunbeam SCA102RPC1 Portable Air...
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
MY GOODMAN AIR HANDLER IS DRIPPING WATER FROM THE BOTTOM
You may have dirty stopped up drain pan or drain. Take a dryvac and **** the drain from outside. This will clear all the drain. Is it cooling ok? Is the unit in an attic? The drain is not hard to clean. Check your coil(evap) inside to see if this is clean. Rus
Jul 11, 2009 | Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
Tom Chichester
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
