Question about RCA HD52W59 HDTV Projection Television
Scattered black lines appear then screen gos black, but still have good volume
Sometimes it may take a few minutes to turn black and other times when you turn on the tv it will never show the video, but audio is fine. I can slap the left side of the tv and picture will almost always come back on. Volume bar is visable when adjusting volume and mute symbol will appear. Sometimes it will alternate back and forth without doing anything and then it will stay black, then I give up. Unit is about 9yrs. old. I also performed the auto convergence. Picture looks great when it comes up. Please Help!!
    Genius:
  • 1,139 Answers
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 25, 2008
SOURCE:
Hitachi 55VS69 screen goes black and there is no volume and it will not turn off unless unplugged.
The key here is you have to unplug it---it means the problem is related to the microprocessor which may become confused because of an issue elsewhere in the set---no real easy answer except it may be expensive to locate and fix.
Mar 19, 2012 | Televison & Video
Large colour lines / bands on screen
Thats your midddle driver board on the botton m8.
Try the technique on this video if that doesn't work ,replace the board by with another of the same part number.Cheap to buy.Ebay.LCDTV Spares shops online
http://www.youtube.com/watch?v=9NPobj0_GSo
Jun 05, 2010 | Panasonic TH-42PX60U Television
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA HD52W59 HDTV Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
