Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Pictures come out with a pink hue cleaned heads new cartridge
I bought a new cartridge and printed a coupl eof pictures and they looked beautiful, but I haven't used it again in about 4 months. I went to print and the colors in the pictures have a pink hue to them now . I cleaned the heads and shook the cartridge but still did not work. Any suggestions? Thanks.
  • dmorgenstern Oct 14, 2008
    I haven't used my printer for awhile. I put a new cartridge in and all my pictures are pink when I print.
Tray cleaning the heads a few times
Posted on Sep 27, 2008
Printer wont produce red on pictures
You need to take out red cart and pull off the tape. It's normally yellow but could be any color. Pull the plastic tape off, and put the cartridge back in, run a few head cleaning cycles and your ready to go.
Sep 22, 2012 | Canon Office Equipment & Supplies
All my picture from my Epson Picturemate personal photo printer are coming out pink. I have brought a new cartridge and it is still coming out pink. Why??
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
May 05, 2011 | Epson PictureMate (C11C556001) InkJet...
My pictures are printing with a purple hue. I
You still have some clogged heads.Head cleaning once is sometimes not enough to clean your heads properly, especially if you are using 'compatible' ink cartridges. You need to clean your heads again, and possibly still again, until your test print pattern produces the correct colours.
Jul 10, 2010 | Canon I960 InkJet Photo Printer
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Dec 18, 2009 | Office Equipment & Supplies
My Kodak printer stopped printing in color.
Hello sir; Are you using remanufacture ink cartridge? if yes, why don't try brand name cartridge, if still don't work, my suggestion go buy a new machine much save more than send to the shop for repaire.
Nov 28, 2009 | Office Equipment & Supplies
My Dad's 3210xi all of a sudden prints pictures in blues & greens
Occasionally printer cartirdges can clog and become unusable after refilling them several times. Also, if a printer cartridge has been "dry" for a long period it may experience the same problem. Your best bet is to buy replacement cartridges for any colours that show problems on the test page. If there is a blue & green hue to your printing that would suggest that the magenta is not printing and should be replaced.
Aug 23, 2009 | HP Photosmart 3210 Printer
Everything prints pink! Head cleaning help on test page but next print was pink again.
I have a Canon S9000 and when this happened to me it was because the magenta or photo magenta cartridge leaked and spread. I had just refilled the cartridge and the plug didn't have a tight enough seal.
I took out the cartridges and used a Q-tip, OK, a TON of Q-tips, with the cleaner fluid from the refill kit on them and cleaned out the bottom of the holders where each cartridge fits.
I also had to do this to the ink ports of the cartridges themselves because they were tainted as well. I ran the head cleaning program a couple of times and once it was as good as it was going to get, I repeated the cleaning of the holders again, bought all new cartridges and ran the head cleaning program again until the problem was gone.
Jul 29, 2009 | Canon S900 InkJet Printer
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
When I print my pictures are coming out cartoon-like.
Brandy,
Try and clean the Gold Contacts on the printer and the print cartridges, Also what Res are you printing them at? You can check that from Prefrences
Rj
Nov 03, 2008 | Epson Office Equipment & Supplies
Pink bars across all pictures in document. Have deep cleaned the printer several times as well as print head alignment. Even changed the magenta cartridge. What should I try next? Thanks, Carol
I had this problem too. I don't know exactly what fixed it but it's working fine now. I removed all the cartridges and then put them back in, and ran through the nozzle check & clean cycle a few times. Now it's printing beautifully.
Jul 13, 2008 | Office Equipment & Supplies
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
605 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
