Question about NEC Computers & Internet
AFW-1430 fire wire card can't find enough resources on my laptop apparently to work
  • 781 Answers
Couple of things you want to try:
0. what operating system are you using? 9x may require for you to manually install and assign resources, 2000/xp should take care of resource asignment automatically
0.1. check if the bios version you have is the latest one, if not try to get an update and install... (backup your data first and make sure you get the right update or you may mess your bios for good)
1. check resource assigning in your bios, make sure your irq's are avaliable to be usuable by your operating system to used in order to assign them to the fire wire card.
2. it may take some time but you way want to check through the properties on each of the devices in device manager and look in the resource tab for any conflicts or
3. go to start > run > msinfo32 and look for hardware>share/conflicts
Posted on Sep 26, 2008
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
Artisan 1430 reads not connected but it is with usb cable
All printers need the proper drivers. Have you installed the correct printer driver?
Here is a link to the 1430 driver page
Epson Artisan 1430 Inkjet Printer
When you look in System Preferences, do you see your printer in the printers and scanners window?
Feb 24, 2014 | Apple MacBook Pro Laptop Computer with...
What type of firewire card can i fit in aspire x 1430 pc
SEE THIS http://www.bestbuy.com/site/IOGEAR+-+4-Port+USB+2.0+Hub/9527933.p?id=1218119228254&skuId=9527933
Apr 21, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Wireless adapter cannot find enough free resources
please try to see if this steps will work. change the startup type of your wifi card into automatic by:
• click START, click RUN
• type services.msc
• look for WLAN Autoconfig and double click it
• change start up type into automatic and stat the process
• hit Apply and the OK
• restart the computer and also restart your wireless router
Hope these helps.
Jun 02, 2010 | MSI (CB54G2) 802.11g/b Wireless Adapter
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
I have a Samsung ML-1430 printer. My laptop isn't acknowledging the printer. I'm connected with a USB. Can you help?
hi, did you get a driver cd with this? if so use that to install the drivers needed for your laptop to recognise this printer, also do you know what operating system you are using? isit Windows XP? or another?
Aug 04, 2009 | Samsung ML 1430 Laser Printer
Fire wire to PC Express
yes...al so known as ieee 1394 ..or fire wire ...or greyhound....it might though prompt you for a driver ...
http://en.wikipedia.org/wiki/FireWire
Jul 18, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Whenever i start game in my laptop it works properly for few minutes and then it starts hanging.... i dono what to do....
Before you run a game shutdown any programs to save resources for it, have you enough memory for those games? 2 or 4 giga will be recomended, check the latest drivers for your video card.
Hope this help.
Jun 25, 2009 | Computers & Internet
Not enough resources to to use AIRCARD 881
Hi there.
Code 12 This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)Cause
This error can occur if two devices that are installed on your computer have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or both). This error message can also appear if the BIOS did not allocate enough resources to the device.
Recommended resolution
You can use the Troubleshooting Wizard in Device Manager to determine where the conflict is, and then disable the conflicting device.
Disable the conflicting device
  1. On the device Properties dialog box, click the General tab.
  2. Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide.
  3. Follow the resolution steps provided by the wizard to resolve the problem.
Good Luck and thanks for choosing FixYa!!
Jun 02, 2009 | Dell Latitude D600 Notebook
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
Computers & Internet Logo
53 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
