Turntable system problem
My problem is in regards to a flaw with my turntable system. I run a record player through a Yamaha RX-V493 receiver and dual speakers. Everything was working fine for the couple years I've been using the setup until I disassembled it to put in storage for the summer and then tried to reassemble it. I couldn't recall exactly how I configured everything the last time but had a general idea.
I wasn't getting any sound when I played the records until I realized that it only works on certain effects settings - my receiver has different settings such as Concert Hall, Stadium, Disco, etc. - and even then each setting worked with varying degrees of quality. The only setting that works somewhat well is Disco, and the only one that doesn't produce ANY sound at all is the "effects off" setting - the only one I ever even want to use. I think I've tried all the different wiring combinations possible that connect the two speakers into the receiver. The only change I've gotten is that the Dolby Pro Logic effect setting (and only this setting) works when I wire the speakers in what I think is called "center" mode (rather than rear, it appears). This seems logical because the instruction manual for the receiver suggested that the unit works best when used with 4-5 surround sound speakers, and I think the Dolby Pro Logic setting is a 5-speaker setup that involves a center speaker while the other 4 do not. I should mention that even though I'm getting perhaps the best sound out of this configuration (either that or Disco), it still does not sound quite right.
Aside from trying different wiring configurations, here's what I've done to try to isolate the problem. First, I bought a new turntable, and ended up with the same problem that occurred with my original turntable. So, I eliminated the turntable as the source of the problem. I then bought a similar Yamaha receiver (RX-V592 as opposed to the RX-V493 I already had) from someone on Craigslist and again the system would not produce sound under the standard "effects off" setting and only clearly under Disco, or Dolby Pro Logic when wired in center mode, so the problem was not a defective receiver either. Today I tried using new speaker wiring to no avail. At this point I figure the problem is either with the speakers, which are probably 25 years old, or in my setup configuration. The latter seems more likely, as I can't imagine why speakers that emit somewhat clear sound under certain settings would be causing the kind of problem I'm experiencing.
I would have assumed that my problem was the result of an incompatibility between the number of speakers I'm using (two) and the type of setup the receiver is suggested to work with (4-5 surround sound speakers), but they've been working fine for me for two years and for even longer when my dad used the system.
Any ideas as to why I wouldn't be able to get my system to work neither consistently nor properly for all the effects settings - or, most importantly, to work for the desired "effects off" setting at all? If I haven't given a broad enough picture of the components I'm using I can try to elaborate on any specific issues that catch anyone's attention. I can also try to provide a PDF of the Yamaha instruction manual if that would help.
I really appreciate your taking the time to read this. My turntable and LP collection have great sentimental value to me - I inherited both from my dad - and I've also invested a lot of my own money in new records over the last year or so. Trying to troubleshoot this whole thing is causing a lot of aggravation and taking up too much time that I should be devoting to studying (although I do sometimes enjoy using it as a nice procrastination tool). I would be so grateful if anyone could help me out with this.
Thanks again,
Brian
    Problem Solver:
  • 5 Answers
Unless I'm missing something in your description, your problem is simple: You need an riaa phono preamp between your turntable and your receiver.
Modern receivers do not offer "phono" line inputs and therefore do provide the amplification required to bring up the line level of the turntable. The result is low or no volume which is what you are essentially describing here.
Just google "riaa phono preamp" and you can either make one for $30 or buy one from $100 to over $10,000 (handmade tube goodness).
Cheers,
NTIMID8
Posted on Dec 13, 2008
  • 31 Answers
Make sure the system is set up for 2-channel stereo only. Then, make sure the speakers are connected to Front Left and Front Right. That should clear everything up.
Posted on Sep 27, 2008
When I plug in my marantz TT-42 turntable to my Yamaha R-S300 receiver's phono input, I get a muddy and loud sound. I've tested the turntable with direct input to Bose speakers and it works fine.
If the turntable produces good sound with a line level input on another system, you have the turntable with the pre amp built in. That is why the sound is loud and distorted.
Mar 05, 2017 | Yamaha Audio Players & Recorders
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
Yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Feb 10, 2009 | Yamaha RX-V463 Receiver
Connecting a Technics SL-BD20D turntable to a Yamaha RX-V463 Rece
After further research, I learned that I need to plug the turntable into a preamp before plugging it into my newer receiver. As with cassettes, record players are fading away. I ordered a preamp, but won't be able to experience success until it arrives.
Jan 16, 2009 | Yamaha RX-V463 Receiver
Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
May 20, 2008 | Yamaha RX-V361 Home Theater Receiver
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
207 people viewed this question
 Grubhead
Grubhead
