Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Bosch classicxx dishwasher not working check water light on
Machine was working ok but has just been replumbed following kithchen re-fit. Water comes from cold main via T piece valve with outputs to c/W tap and dishwasher. Cold tap pressure good. Dishwasher starts and empties but tries to fill and gurgle sounds heard. Check water light on after 1 minute and filters in line are clean and ok. Pump empties small amount of water. How do I access inside the machine if you can identify potentila problem
  • 409 Answers
He there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
Posted on Sep 25, 2008
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a Bosch diswasher model SGS44E12EU it is not filling up with water when turned on and so the cycle does not work.
hello, check the pump first make sure theres no water left in the machine if ok then check water supply to the machine if this ok then the cause could be the water inlet values on the machine make sure they are not blocked hope it helps
Mar 26, 2011 | Bosch Dishwashers
No water is getting inside my Bosch dishwasher compartment. Water supply to dishwasher is ok. Checked hose at input of dish washer and water supply is ok. Could pump have packed in? Model 004 920 378....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
Sep 08, 2010 | Bosch Dishwashers
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
Hi, I have been away for a few weeks and now fi...
Check whether water is flowing into the machine. Disconnect and check the water flow at the machine connecting end. This is user serviceable portion and no special tools required. Check the strainer submerged in to the small pipe on the machine body. Clean if blocked.
To ease matters further pour water into the wash chamber manually to a required level. Run the machine. if OK only your incoming water problem.
Finally check the inlet solenoid valve & its associated circuitry if problem persists. Take help through the authorized service provider.
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
My bosch excel dishwasher has the following fault: start the cycle, water starts to fill but then check water light comes on and it then starts to empty again. Pump then keeps going. I have checked the...
this unit im sure has a water flowmeter that measures the water intake.. if this cannot read then the unit shuts down to avoid flooding..
it needs replacing... it is attached between the valve and the side tank or attached to the tank dependant on model...thanks
Dec 18, 2009 | Bosch Dishwashers
Bosch dishwasher model SMU4052UC/14, Won't fill
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
May 06, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Bosch 4302 dishwasher
Water supply to the dishwasher is done through an electromagnet valve,located at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
May 24, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
1,162 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
