Question about Canon imageRUNNER 1023iF Black and White Copier
CANNON NP1215 COPY MACHINE
My np1215 shows an error code of OOO on the led. This came about when we tried to pull out a piece of paper from the manual feed while it was being drawn in. Since that time it has not worked.
We tried unplugging to reset but this did not work. Any ideas to help fix this problem will be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Coiincidence ??? E000 is a fuser error
Posted on Sep 26, 2008
Download Cannon resetter for error code 5B00 model MX416
FIRST STEP : ENTER SERVICE MODE
<Service mode operation procedures>
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the
buttons). The COPY button lights in blue to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each
time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in blue, starting
with Alarm LED.)
4) When the COPY button lights in blue, press the Stop/Reset button 4 TIMES
SECOND STEP : DOWNLOAD THE FOLLOWING PROGRAM.
www.4shared.com/get/zc4OMn2_/Service_tool_v3400.html.
1. Run the program
2. Set the region according to your location, then klik set
3. klik set on the Ink Absorber Counter
4. Prepapre 1 sheet of paper.
THIRD STEP : TURN OFF YOUR PRINTER AND THEN TURN ON AGAIN.
FINISH
Sep 06, 2012 | Canon Office Equipment & Supplies
Need service manual for canon copier np-1215
hello, you can find the canon np1215 series service manual in below link:
http://goo.gl/1sdGnj
thank you
Apr 27, 2012 | Canon Office Equipment & Supplies
Sir, i have a canon NP1215 machine problem is text is ok but photo or any image is not good it is comming so dark.
you can try adjust image density manually (a small regulator located on front panel or under the front cover, depends on model)
May 19, 2011 | Computers & Internet
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
I ot a cannon NP1215 copy machine an d it gives
Low fuser temperature, Lamp, thermal switch, themistor or A C driver
Jan 15, 2010 | Canon Office Equipment & Supplies
Persistent E3 error message (jam)despite there being no paper in the machine - will not clear
  1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 1023iF Black and White Copier Logo
217 people viewed this question
old marine
old marine
