Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC 9420cn "unable to print see troubleshooting...users guide"
I've look at the user guide and nothing in there helps. I looked at your web site for comments too.
As soon as I power up the printer, I get the message "unable to print" "see troubleshooting and routine maintenance chapter in user's guide."
THere have been times in the past after power up that the printer would print one time and then the above message comes up. Of course when the message comes up, the printer will not print.
  • 3 more comments
  • astropup98 Sep 27, 2008
    I have the same exact probem. I've gone through the user's guide to troubleshoot this and to clean everything as the manual suggests, but still the same problem. Don't know how to resolve this problem.
  • andersonjunk Oct 30, 2008
    I am having the same exact problem. The FAQ on Brother's web site says to contact a service center. I was hoping to find someone on line that knows what causes this and has a resolution
  • Anonymous Nov 02, 2008
    "unable to print see troubleshooting...users guide" problem, and notify you when a new solution is offered.
  • sandra494 Nov 02, 2008
  • AA-Man Nov 13, 2008
    Same problem, my machine has 1728 pages on the counter. It has been in storage but worked fine for past 3 months. I phoned Brother Service dept and they said it was a error #25 and would need a tech. I called them and they told me they only worked on buisness machines and my best bet was to buy another printer. Lot's of help there! Practically new machine and serching for help. Thanks
    Scholar:
  • 78 Answers
Ctstore,
Your unit requires replacement of its maintenance kit. You will not be able to do this by yourself unless your are a technician, which I assume you are not. The cost for this repair will not be cheap, you are going to be up for over $500 and you need to do it through a brother warranty service centre.
Gremlin11
Posted on Dec 10, 2008
alphacheese
  • 68 Answers
SOURCE: brother mfc-21c....says, unable to clean..see
Try running a purge count through the maintenance menu. You can enter maintenance mode by pressing: Menu> * 2 8 6 4 Press 8 0 Scroll down to purge count value. You should get there after pressing the down key 24 times. Press 2 7 8 3 to reset the purge count. The printer will then restart. Then try printing again.
Posted on Jan 08, 2010
sardanadixit
  • 813 Answers
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Download the manuals from:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
and
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_110C_MFC_210C_3240C_3340CN_420CN_5440CN_5840CN_620CN_EN_1266.PDF
Please rate this solution in case you find it helpful, else leave a comment and I shall revert back with more suggestions.
Posted on Aug 11, 2009
Testimonial: "Thank you for the site info! i looked for a long time, wish i had asked and followed your advice the first thing as it went right to it."
Mix-it-up
  • 832 Answers
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Posted on Mar 08, 2008
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
UNABLE TO PRINT, CHECK ROUTINE MAINTENCE AND TROUBLESHOOTING I
Could be many problems. Did you get a error code number? If so, look for that in the manual or go to the brother website and check
Jun 16, 2010 | Brother MFC-9420CN All-In-One Laser...
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing after being on same phone line as printer/fax
This link will open the Users Manual, but you will need a PDF viewer such as Adobe Reader or Foxit Reader in order to open it.
Go to page 12-4 in Chapter 12, Troubleshooting and routine maintenance. Follow the actions recommended for the Unable to clean error message (and the four other Unable to... error messages).
Jul 04, 2008 | Brother MFC-3240C All-In-One InkJet...
PRINTER SAYS UNABLE TO PRINT USER'S GUIDE CHAPTER TROUBLESHOOTING
This is a common problem. If this is under warrenty get it repair or exchanged. There is a lot of people on here that are having the same Problem
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-9420CN All-In-One Laser Printer Logo
1,739 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
