Question about ASUS A7V333 Motherboard
No boot up
I have disconnected everything except for the memory and AGP card (no on-board graphics). I started it once before and it booted fine, but then I installed everything back and it wouldn't boot. I unistalled everything again, reset the power supply and now it won't boot, no beeps, no monitor signal. That's where I'm at. Now what?
  • drdoolittle1 Sep 26, 2008
    Found out through some more searching that my board has a voice-over troubleshooter. I hooked up some headphones to the audio out and booted up. It said, "System memory failure" I moved the memory around and got it to work. Apparently I have a memory slot gone bad. Oh well, I still have two slots available. Your advice helped get me in the right direction, thanks for taking the time. I will also be able to use your advice for future fixes if need be.
    Problem Solver:
  • 7 Answers
Try removing all memory except one board. If it does not come up switch boards. Still no luck, check power supply if you can or switch it with another. A power supply checker is pretty cheap, 10 to 15 dollars, and well worth the investment, although it is not foolproof. Try switching PS off, physically remove the BIOS backup battery, then replace it and try again. That should have cleared the BIOS back to factory defaults. It sounds like a memory problem, but as a last resort, you might reseat the CPU. The CPU fan runs, yes? Can you get some other memory to try? Well good luck!
Posted on Sep 25, 2008
My Shuttle AV49P motherboard would not bootup. The system is powering up, & the drives are spinning up. There are no beeps & no infor on the monitor. Monitor is working, AGP Graphic card is...
You should get one bios beep. You seemed to have tried everything except a different hard drive. Check the capacitors to see if they busted open. Other than that the motherboard could be fried. Hank
Aug 18, 2010 | Shuttle AV49PN Motherboard
Motherboard won't go to boot sequence
Check the power supply if its giving the correct voltage on the mother board.
I know you're going to say it have power, but sometime it happens, It happend to me once, there was power and everything check everything and its working fine but when i put it back together nothing's seem to be working. I swap the power supply and bingo.
Mar 31, 2009 | ASUS P5S800-VM Motherboard
I have a Sony Unit - with ASUS P450-VX motherboard. I put in a AGP video card in it and it works fine except on cold boot -in POST, The onboard video is used (only on cold boot - once the AGP card is...
I'm not exactly sure what you are explaining but to disable in Windows go to: My computer: Properties: Hardware: Device Mgr: Graphics Card and for the one listed that is not your AGP card click: Disable This Device. It's just that simple. Also, in some BIOS,maybe all, there is an AGP: enable/disable box. This of course should be enabled.
Dec 11, 2008 | ASUS Terminator P4 PC Desktop
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
System reboot and lockups with AIW2006 AGP running Windows XP
hmm..memory allocation issue? how much you got on board that machine?
Feb 19, 2008 | ATI ALL-IN-WONDER 2006 EDITION, (256 MB)...
Installing AGP video card
Don't boot with the monitor connected to the card. You need to let it boot into windows and install the drivers for it first. Once you do that,shutdown and restart with the monitor plugged into it and it should work.
Sep 13, 2007 | Sis 6326, (4 MB) Graphic Card
System don't Reboot
Assuming you have already installed the AGP driver for the motherboard, you will have to start the pc in safe mode (F8) on boot up, to start in VGA mode only and see if the graphics are ok. If it boots into VGA mode then the card itself is ok, but the card driver and agp motherboard driver, if not already; will need to be installed at this point because im assuming you were not able as you were getting the fault on screen.
May 01, 2007 | Pine Technology TLSI211004 Motherboard
AGP cant work and Memory issues
Are you certain that your AGP card is 4x or 8x? It seems that is the only kind this one supports. Not sure what the 2 beeps mean in post but it obviously doesn't like your AGP card. Report this info to MB customer support. There do not appear to be any jumpers to manually disable on-board AGP as it is done through BIOS settings only. Also, you might want to first install the AGP drivers using the onboard gfx and then install the Gfx card. As for the memory, I have no idea. Perhaps you could contact the manufacturer or return the MB to fry's for a replacement?
Oct 31, 2006 | EliteGroup P4M800PRO-M Motherboard
ASUS A7V333 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
