Question about OKI Office Equipment & Supplies
Wrinkled paper - OKI Office Equipment & Supplies
  • 928 Answers
Hello may i ask if you received my messages?
Posted on Sep 25, 2008
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
My printer wrinkled the paper when it is out
Try using fresh paper from a new ****. If still wrinkles might be an issue with your fuser. The fuser is the part that heats the toner onto the paper and if the paper contains too much moisture content (from improper storage methods), this can cause wrinkling effect as well.
Try printing with different types of paper and from manual tray to isolate problem. If it occurs all the time, most likely bad paper or bad fuser.
Jan 16, 2010 | HP LaserJet 4200 Printer
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Wrinkled paper
Try checking the fuser unit inside the back of the printer. Open the door and pull the paper path tray down. You should see an orange vinyl looking roller. If is has wrinkles it probably needs replacing. I have replaced two on my printers and that corrected the wrinkling problem. You can get them on ebay.
Oct 24, 2007 | Brother HL-5250dnt Laser Printer
154 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
