Question about Sanyo DS31520 31" TV
No vertical sweep on my Sanyo DS31590
I've had this tv for about 7 years and just today the screen just had a white line in the middle of it. How could I fix it?
  • shorty_666_u Dec 01, 2008
    I have a white line going through the screen im am trying to locate the heat sink to try to fix it can you help me
  • Anonymous Dec 03, 2008
    no picture and a white line threw the middle cross ways
  • 4,234 Answers
This is a fault in the vertical circuit. It can be either a bad solder connection of the vertical IC or a defective IC. If you can solder, you can fix this yourself. Open up the back and locate teh vertical IC. It willbe a small flat IC attached to a heat sink and be marked LA7841. Resolder the pins first. If that fails to resolve the problem, replace the IC. Please note that there may be capacitors in the circuit that need to be changes as well, but without the chip working, it will be difficult to determine which ones. Update this once the IC has been resoldered or replaced with the results and we'll continue if necessary.
Dan
Posted on Sep 25, 2008
  • 3 Answers
IC 501 LA7841 Bad can use LA7845
D483 600PIV @ 1A  Shorted
R483 1 OHM 2Watt fusable type resistor is best
Posted on Jan 22, 2010
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
Video and audio issue on my Sanyo DS31590 T.V.
line left to right is vertical circuit problem and may be linked to audio problem if both are fed voltage from a common source---Not a do it yourself repair unless have experience with this kind of equipment.
May 15, 2012 | Televison & Video
A thin white line running horizontally in the middle of my screen. the rest is black.
The vertical sweep driver has failed. Get an estimate at a repair shop to see if it is economically feasible to repair.
Oct 21, 2009 | Sanyo DS25390 TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Dan
Feb 24, 2009 | Sanyo DS31590 31" TV
Manual
did you try their web site
sanyo.com
Feb 03, 2009 | Sanyo DS31590 31" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Sanyo DS31590 31" TV vertical deflection
If the vertical is not defective or shorted there is a possiblity of bad solder connections on the vertical ic. If connections are good and has b+ voltage to the chip replace chip which is IC 501 LA7841 or LA7845 and change c511 (decimal point 1 film capacitor)
Dec 28, 2007 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Sanyo DS31520 31" TV Logo
211 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
