Question about HP Compaq nc6220 Notebook
Processor speed doesn't match my Processor
Hi,       When I look at the computer information from the start menu.  it shows that i have a 2.0 Ghz processor and it's running at 800 Mhz.  Is this a software issue?  or can I enter the bios and raise my processor speed to the full potential.  I even ran Belarc Advisor through my machine and it confirmed my processor speed.
Thank you
  • HP Master
  • 4,338 Answers
Go to CMOS and set the right settings.
Posted on Sep 25, 2008
I have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting (see the Below ) to research and figure out which processor you want. Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Jan 21, 2013 | eMachines EL1333G03w (884483010820) PC...
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
Hope this helps. Thanks for using Fixya.
Jul 13, 2011 | Computers & Internet
Windows Not Showing & Not Supporting Actual RAM installed.
make sure that you don't need to overclock your setting (in BIOS ) so as to get full ddr3 frequency.That it, you need to overclock your CPU speed and if you want to work at great speed, try you upgrade you processor.
try a core 2 duo or a quad-core and make sure that it matches with your FSB, with maximum L catch ( 12 mb)
Jun 24, 2010 | Intel D845GVSR Motherboard
My AMD Turion processor powered laptop runs slow intermittently
good day i also use a compaq laptop and i think you laptop is very fine just be frank you have so mch game in your laptop and am sure thats it.want does game increase your ram to maybe 4gb.
Jul 05, 2009 | Computers & Internet
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
Need 2 install the fastest PIII processor possible on CpxJ650GT
you obviously seem to have the adequate knolledge so why dont you overclock it...
overclocking used to be a touchy subject but know its undrstood that that it creates no problems..the chips are designed to be overclocked,in fact overclocked should now not be the trerminology for it was called overclocking cos then it wasnt natural and created unstable systems it is merely enhancing .
Jan 24, 2009 | Computers & Internet
you can see this by right click on my computer icon on desktop ,go to properties ,then under general tab there is system line which show what is your processor speed & ram
for more information go to hardware tab,then device manager,window is opened which shows components attachd to your pc
Oct 29, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
Computer shuts off
go to the bios then check, your processor deatials
Oct 24, 2008 | Computers & Internet
Processor slowing down?
On the system properties you will able to check your processor speed and your memory, it is possible that the other description is referring to your memory or Ram.
You can use other program like aida32 to check your computer spec or you can try the steps below.
To check the CPU speed, from the Start menu, select Run... , then enter msinfo32 .
You can also type DXDIAG then enter.
Mar 07, 2008 | Computers & Internet
Dell Optiplex gx270
Hi, reset the BIOS u need to follow below given steps(Perform all the steps carefully )
1.Restart the notebook.
2.Tap the F10 key as soon as the Dell logo appears.
3.Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes".
Oct 14, 2007 | Dell OptiPlex GX270 PC Desktop
HP Compaq nc6220 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
