Question about Frigidaire Kitchen Ranges
I have an F 2 error code going off on my Frigidaire self cleaning wall oven
  • 750 Answers
Mirandash453,
Welcome to fixya.
I'm Huuum and happy to assist you,
What is the model and age of the wall oven?
This may help, but without the model number I can not be sure.
Send me this information and try this procedure below too!
waiting for the info!!
Huuum
You said, you have an F 2 error code going off on my Frigidaire self cleaning wall oven
Electronic control has detected a fault condition. Push CANCEL to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record
the fault number, push the CANCEL pad and contact an authorized servicer.
Posted on Sep 25, 2008
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
Aug 16, 2013 | Frigidaire 27 in. Electric Double...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
Kitchen Ranges Logo
192 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
