Question about Canon EOS 40D Digital Camera
Canon 40D display on top of camera
9 month old canon 40D still functions but the display on top of camera will not show setting changes. Almost all icons are illuminated. Again, the camera still works and I can check settings on the back display but top display is locked. Any solutions besides sending it to NJ for 3 weeks would be greatly appreciated. Thanks
  • 31 Answers
Sounds like you are stuck sending it off for repair. I know no other way.
Posted on Aug 16, 2010
Why are no photos being displayed on screen after shooting?
PDF]PDF QuickGuide to EOS Live View Features
https://www.learn.usa.canon.com/.../CDLC_EOSLiveView_Q...
Canon Inc.Canon EOS cameras when used in their Live View mode. ... directly onto the sensor, which in turn displays the image ... EOS 40D, 5D Mark II, EOS-1D Mark III, EOS-1Ds Mark III, ... Mark III do not offer movie options. ... to produce a fixed screenbrightness, or Exposure .... settings for the following camera menu options:.
Canon Knowledge Center - Changing the AF Mode to Use ...
https://support.usa.canon.com/kb/index?page=content&id=ART134415
Nov 4, 2015 - ID : 8201360200 _ EN _ 1. Solution ... While the Live View image isdisplayed, you can press the < AF?????????DRIVE &gt; button to select the AF mode on the setting screen displayed. 9. ... If focus is not achieved, the AF point will turn orange. .... Shooting movies with the default settings (EOS 5D Mark III)
Dec 25, 2015 | Canon EOS-1D Mark III Body Only Digital...
When viewing my imiages I have taken n my canon 40D I see 9 at a time how do I change it back to 1 at a time
At the top right of the back of the camera are the two buttons for AE lock and Focus point selection. One zooms in, one zooms out. Press zoom in once,.
Oct 14, 2013 | Canon EOS 40D Digital Camera
I currently have a Canon 40D, the problem is... 1)When I take pictures, the bottom 4/5th of the screen is cut off, as in it is black. But the top will show the picture 2)The Liveview function works, but...
Shutter speed too high...1/250 violates the max flash synch speed of most FF cameras....the shutter is not fully open at that speed when the exposure is made, and you are seeing one curtain at the black band.
May 05, 2011 | Canon EOS 40D Digital Camera
40D shuts down when shutter pressed
avoid getting milked get the camera back asap how much is a pound in dollars anyway...
Try a new set of batteries the snap of the shutter may be just enough to load down a weak battery array warranty is warranty and they have the rest of the world that still may buy theor stuff and all thecompanies are the same. Hey that is giving the business, Silent protest and it is silent. No matter how loud you are yelling grab their purse strings when you can they are connected to their unit between their toes. Yea there large toes.
Jul 27, 2009 | Canon EOS 40D Digital Camera
Menu options for Canon E0S 40D have changed
Make sure that you didn't dislodge the memory card when you put in the battery.
Note that you can get a memory card reader to read the contents of the flash card directly on your computer.
If the 40D is like the other Canon DSLRs that I have used, you can put an update on the flash card that will update the camera's firmware.  You might need to go to the Canon side and download new firmware to update your camera.  Instructions should be on the site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=17779#DownloadDetailAct
Apr 25, 2009 | Canon EOS 40D Digital Camera
Canon EF-S 17-85MM F/4-5.6 IS USM prevents features from working on 40D
something sounds strange about this. aperture 00 is an invalid aperture value. stands to reason if that is the case the camera would complain about it. via error code. being that its only six mos. old i would give canon a ring.
Oct 11, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens won't allow me to change aperture & several other functions on camera
The USM engine may be out of order, or there is a bad contact in the lens.
Manual shooting mode problem.
The exposure compensation dial (at the back) doesn't work when you're in Manual. In Manual, you set the shutter speed and aperture to get an image with the amount of over- or under-exposure you need. In the view finder, the "exposure meter" at the bottom shows how much light there is where the lens is pointed. When it shows what you called "2-stops", its really underexposed. Thus your black images. You need to increase ISO, open the aperture and slow down the shutter speed (or a combination of these 3 options)
Set your camera to P or full-auto. Do the photos turn out ok? If they do, then there's nothing wrong with your camera and you just need practise on the Manual mode.
Aug 13, 2008 | Canon EOS 40D Digital Camera
Error 99 Code on 5 month old Canon 40D
error 99 can be several things. Try the following. Check that the contacts on the lens housing are clean if not clean them with a swab of denatured alcohol available at walmart. also if there is extremely cold weather your shutter could be creating the error. Try using a blow dryer and on the warm setting warm up the camera with the lens off. Blow around the mirror area. I know it sounds silly but it has worked in the past. Good luck.
Feb 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
