Question about Sony KV-32HS20 32" TV
Shuts off intermittently
The standby blinks 5 times. The diagnostic screen shows AKB circuit.
Also could be IK blanking. One solution is to" turn up the screen".
How do I do that? Do I need a Pro to fix this?
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
This is issue with the tv : * 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.Needs pro to fix this...
Good luck,,,,
Posted on Sep 26, 2008
  • 1,879 Answers
Auto Kine Bias; a circuit that holds the video OFF until the picture tube (kinescope) is warm enough to run video. So, if there is trouble within the AKB it may not be turning on the crt. Or, the crt could be cold, or there could be power supply problems (which I favor because if the audio is gone too, that means it is not a "video only" matter).
  • 10,594 Answers
You need to adjust G2 voltage (Screen volts) in tv to resolve IK problem.
Need further assistance, let me know.
Thank you.
  • Shahid Electronics
    Shahid Electronics Sep 26, 2008
    Hi again,
    Look at below picture and find the Screen Control to adjust volts to fix IK problem.
    Adjust RV9002 on the C Board so that the voltage on red, green and
    blue cathodes is 170 V DC.
    Regards,
    Regarding your question, how do I do that, it depends on your skills and knowledge.
    If you think, you can understand above information and can do the job, thats ok...or call tv tech guy to fix it.
    Master:
  • 726 Answers
Its the main power supply that will be gone can fix your self but will be hard
Posted on Sep 25, 2008
  • chris07551 Sep 26, 2008
    AKB circuit is the screen display then you will have to replce that and its difficult so yes you should see a professional as this might cause electrcution if done wrong plz rate this soulution
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to check the power button
may clean could fix
try to open it use tools then unscrew
then check the power supply if it is ok
or replaced the power supply
Sony code 5 ?
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 09, 2012 | Sony KV-36XBR450 36" TV
Sony kv-27v40 standby/timer blinks 5 times
Apr 23, 2012 | Sony KV-27V40 27" TV
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
Mar 09, 2011 | Sony Televison & Video
KV32CS76E red light blinks 5 times again and again totaaly blank screen
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Feb 02, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No sound, no picture standby light blinks 5 times, pauses, blinks 5 times, etc. This is a Sony Trinitron 36" Wega tv about 7 years old.
Nov 12, 2010 | Televison & Video
No power
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slight
Jun 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-32fs120,no power:3 and 5 blinks
http://www.riddledtv.com/forums/sony-kv-32fs120-dead-blinks-5-times-t329.html
Thank this guy and you need to see a qualified repairman
Chassis BA6 for anyone elses information:
I would check the Bridge rectifier first to see what voltage you are getting. I have a note here to check D611 which is the bridge rectifier.
Here are the Sony blink codes:
Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.
Apr 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS12 Lost Green
Hi!
Five blinks means - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 28, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Just sound
Feb 26, 2008 | Televison & Video
Sony KP-57HW40
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KV-32HS20 32" TV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
