Question about Echo Garden
Echo PB 400e backpack blower "Adjust"?
I own a Great piece of Landscape equipment. It's a Echo PB 400e Backpack Blower. The best piece of Landscape equipment I own. This is the first problem I've ever had with it, that I could not figure out.
What I need your advice on, is: "How to adjust the carburator"? It will run, but not at high RPM. I have "tried" to adjust the carburaotor myself, but it simply is not operating at what it is capable of Last week I "thought" that I had it (fairly) well adjusted, but no! It ran (ok) for a few minutes then it simply would not, nor will it, operate at full throttle. Nor has it done so since last week. I have (Incorrectly) turned the 2 adjustment screws, on the carburator, in vain attemepts to get it to operate properly. Additionally I have (Incorrectly) adjusted the one larger adjustment screw, on the carburator, that is right next to and under the "choke" lever. If this screw is screwed to far out the choke lever will not operate properly. It interferes with the choke lever. Preventing the choke from being fully applied.
Perhaps there is a basic series of revolutions 1 way or the other, that these adjustment screws are supposed to be set at? Also do you have a service manual for this unit availble for sale? If so, can I order it through you? Where, if it's available, can I obtain a service manual for my Echo PB400e Backpack Blower?
If possible, your advise and assistance will be greatly appreciated.
Thank you,
Jerry
  • jerrj1957 Oct 10, 2008
    I want to thank you Chad for your good suggestion. I agree that fresh fuel is essential, especially for a powerful blower like the one I own. By the way I did as you suggested and drained the old fuel out, plus I purchased and installed a new fuel filter. The old fuel filter was all gunked up with some type of petroleum build-up. The new fuel filter helped quite a bit. I will do as you suggested in buying a new spark plug also.
    It turns out that the fuel was not the problem though. It was the carburator being out of adjustment. It took a matter of trial and error to eventually get the thing to running like it is supposed to. I had recalled from many years ago, a carburator adjustment method of turning the adjusment screws all the way in, then loosening each at a rate of 1/2 a revolution at a time. This worked out perfectly. It runs as good as ever. My next move is to find and purchase an owners manual. If possible, taking the guess work out of the equation is always best, I think.
    Jerry
Hi. Does anyone know what year my Echo pb 400E Backpack blower is?
Posted on May 25, 2010
    Scholar:
  • 62 Answers
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. Not fresh from the gas can, fresh from the pump. And while the gas and oil mixture should be right, it can be off a little bit and still run....but fresh gas is essential! Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
The problem with my pb400e is simular, however the main problem
my unit has is fuel pouring out of the caberator. I bought a new carb, but when I installed it the same thing happened, fuel pouring out of the carb. I took out the carb looked into the cylinder and noticed the piston does not look like it comes down far enough to burn all the fuel, and maby thats where the fuel is comming from. does this sound like maby the end of the life of this motor.
thanks
by steve fireman 5-
Posted on May 27, 2010
The operators manual can be located here. Hope this helps. http://www.echo-usa.com/documentation.asp?Model=PB-400E&lang=
Posted on Nov 01, 2008
Echo leaf blower pb-261l part#10491011410 the part broke between the backpack and blower got the part off the backpack one is still in blower how to get that out
Take apart the blower and then re-assemble it according to the manual then you should be able to find and fix the problem.
May 18, 2017 | Echo Garden
My pb413T want to run only on choke
Its a lean condition... Its not getting enough fuel. Check fuel filter and fuel lines, be sure to use fresh fuel then either adjust the carb or rebuild it.
Jul 12, 2014 | Echo Pb - 413t Backpack Blower
Echo backpack blower bkue smoke
Sounds like mixture is too rich. Get correct mixture per manual and refuel.
Jul 11, 2014 | Echo Pb - 413t Backpack Blower
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
Not getting fire to plug,replaced ignition still no spark,echo pb-400e
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
Jul 29, 2011 | Echo Inc. 25.4 CC Backpack Blower
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Garden Logo
4,415 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
