Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Gallery Series Side by Side doesn't crush ice
Ice maker doesn't dispense crush ice now.
Dispenses water, makes ice cubes, dispenses ice cubes. Crushed Ice lever dispenses whole ice cubes with a few ice splinters.
  • 5 more comments
  • garzons Sep 25, 2008
    It's actually a Frigidaire side by side Gallery professional series FRS24ZSF and it is similar to many other Gallery models.
    But if you are talking about the metal arm which swings up as ice is made, it is still moving. Ice cubes are still being made and filling the bin. Ice cubes still come out the front when you press the glass to the outside lever.
    But when you swing the knob from the cubed ice to crushed ice, only cubed ice still comes out with a few ice splinters like the crushed ones that use to.
    Sure hope you can help!
  • garzons Oct 22, 2008
    Sorry -- called away, back now. Still dealing with issue of got water, got ice but doesn't dispensed crushed ice. You asked if front panel pulls off - it did. There was a second cover underneath which I pulled off to find wiring. Totally lost at this point so I put both panels back on. Still dispenses water and ice cubes, so no foul.
    But what do I do now- do I need an electrician?
  • Anonymous Mar 13, 2014
    Freezes cubes but won't dispense
  • Anonymous Mar 14, 2014
    frigidaire gallery series side by side makes ice just fine but wont dispense it all other functions work
  • Anonymous Mar 20, 2014
    ge gss25 icemaker wont dispense ice cubes, only dispenses crushed ice
  • Anonymous Mar 22, 2014
    digital panel wont change to water, or crushed ice ,stays on cubbed ice
  • Anonymous Mar 31, 2014
    There are normal cubes in the container. No matter the control setting, only crushed ice dispensed. The water dispenser works fine.
    Sergeant:
  • 409 Answers
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • Carmen Mikulic Sep 25, 2008
    hi there,
    sounds good, just wanted to make sure that the arm isn't stuck.
    in this case it must be one of the 3 microswitches behind the dispenser.
    would you have the capability to take the front casing off the dispenser?
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Ice maker only dispenses crushed ice
You guys are great. I just pushed down on the lever in the back and once again I have cubed ice!! Thank you!
Aug 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Refrigerator Ice maker
You have to make sure that themetal rod is placed over the rectangle lever in the back of the freezer....... When you pull the tray out the rectangular lever goes up...you have to pull it back down and make sure to place the metal rod through the rectangular shaped thingee in the back.
Jul 28, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
2,222 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
