WM3431HW all in one washer/dryer does not power on
Ive had this washer/dryer for about 6 months and last week it just wont turn on anymore. for about a week prior to this the dryer seemed to not work as well and would take twice as long to dry. Now it wont turn on and if you unplug it for about 15 seconds and plug it back in it will chime but no lights come on and it still not working at all.
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
SOURCE: E20 message
The filter is blocked. Disconnect your power source. Open the panel. Have a towel or wet vac handy and a screw driver. There is a silver ring circling the drainage hose with a small screw on top. Loosen the screw. Pinch the hose on top and let water drain to wet vac or towel. Completely remove the hose from it's housing. Reach your thumb and index finger inside that same hose and pull out the filter. It looks like a small plastic cup with holes in it. Clean it out, wash it. Use your fingers or dry vac hose and feel the bottom of the inside of the hose where the plastic cup came from. Remove any debri that excaped past the filter with fingers or suction with hose til you can feel with your fingers that the bottom of the inside of the hose is clear. return the cup back inside the hose. Put the silver ring over the lip of the hose then place the hose back on it's metal housing which is attached to the machine. Make sure the hole is secured around the entire metal (if not you will get leakage). Tighten the small screw, pull down at the hose making sure it will not come off with the pressure of the water. Clean up any leakage. Close panel and I promise you, your problem will be solved. Good luck, from Cheryl AlAlexander
Posted on Jan 18, 2008
SOURCE: LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
turned out to be the control board and the transformer - an expensive fix!
Posted on May 27, 2008
Master_Tech
  • 770 Answers
SOURCE: dryer won't turn on
whats your email?
Posted on May 31, 2008
vanni7
  • 163 Answers
SOURCE: washer won't turn off
Hi!! You need a new timer for your washer machine..they can be very expensive so look around..Good luck..
Posted on Jan 04, 2009
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tip
Keep your dryer running how it should and save money
service your dryer every 3 months if you use it 3/4 times a week 2 times a week every 6 months it is important easy to do yourself but make sure you turn the power off 1st depending on the make or model you need to get into the inside of your dryer and vac all the lint and dust out all around it builds up on the motor and heater fan if the motor fan gets blocked it will cause the dryer to stop and you will have to wait till it cools down for it will start again not good as the motor will burn out or could catch fire if you follow my advice your machine will last longer and work better
on Nov 06, 2011 | Hotpoint Dryers
Front door is locked and I cant get my clothes out.
http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp
Check this link, and click on the right side, for the pdf file, to read the manual. Hope this helps.
Mar 29, 2010 | LG WM3431 Front Load Washer / Dryer
Where can i find a free service manual for LG WM3431HW?
Unfortunately you won't find one.
LG only supply their servicing manuals to their repair centres and strictly enforce their copyright, so the manuals are not available to the public and when they do occasionally appear the material has been stolen.
Usually I'd recommend a generic repair manual such as the one by Haynes, but LG's direct drive system and a number of other unique technical features mean that the Haynes book isn't as useful as it could be. The WM3431HW is a large capacity and technically advanced washer dryer so it's certainly not as straightforward to service as a traditional front loading washer or dryer. Many LG spare parts can also be difficult to source outside of their own approved servicing organisation.
I respectfully suggest that you either get LG to fix your machine or post a question on this site describing the problem to see if we can assist you.
Mar 26, 2010 | LG WM3431 Front Load Washer / Dryer
LG WM3431HW is flooding the room
take the lid off
check your inlet valves are they ok
take the back panel off and check all your hoses
find out what is leaking and then i can help you to take apart further
make sure that you unplug it first though.
Feb 12, 2010 | LG WM3431H Washer and Dryer
Dyrer wont turn on at all whirlpool duet front dryer??
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
If all checks out OK above, replace the control or, timer module.
Jun 07, 2009 | Whirlpool GEW9200L Electric Dryer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Splendide 2000 Vented won't work
If you are talking about you have power to the washer/dryer but the machine won't even turn on, won't spin, won't add water, won't turn on dryer, then your situation is like mine right now. Last week with the same situation, we remounted the security switch in the door lock where the little hooks goes into the washer and the machine worked for about a week. Now the same thing is happening and I am looking for a replacement switch.
I definitely need help in getting the washer out of its cabinet and get the cover off in order get to the switch from above.
Jeff
Aug 31, 2008 | Splendide 2100 Vented Washer-Dryer
LG WASHER/DRYER
Try checking the back, there is a plastic tub that is connected to the drying system and it can get clogged with lint etc. It will also cause the unit to give you longer drying times. It is a poor design. You can also pop off the lid to get a better look but make sure you unplug the unit.
Sgt 48
Jun 09, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
