Question about Frigidaire Refrigerators
Fan is blowing but there is no cold air coming out
  • clzwyghuizen Sep 25, 2008
    More info: I just moved, brought the fridge with me. I plugged it in and thought it went into defrost mode. Then the only thing that got cold after 2 hours was the bottom portion of the freezer. The fan is on but no cold air is blowing out of it.
  • 943 Answers
Hi thanks for the question when you moved the fridge did you lay it down if you did lay it down then you have a big problem if the whole evaporator doesn,t get cold you have a compressor problem thanks the appliance doc
Posted on Sep 25, 2008
Fan blower blows cold and hot air
most likely a stuck heater tap,but may involve vacum or elec controlled trap doors in HVAC system
Mar 15, 2015 | 1999 Dodge Dakota
Byant ac not blowing cold air
Check outdoor unit ,if the outdoor fan is spinning ,check if the compressor is coming on , if both fan and compresseor are working
it may be low on refrigerant
Jul 01, 2014 | Bryant Heating & Cooling
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Does not blow cold air
check your compressor first to see if it comes on, then the freon inlets and outlets. one side should be hot or warm and the other should be cool or cold. If not 1. check the fan or blower for the cooling fins to see if it is blowing. 2. call your manufacturer to see if a capacitor or switch could cause the apparent problem (either the cooling fan not blowing or the compressor not coming on) . this info is for a house a/c but should not be muich different
Jun 09, 2010 | LG GL6000ER Air Conditioner
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
Fan blowing air not coming in the house blowing threw vents
check to see if those ducts have dampers if the do make shure there open and if they are open maybe close some of the others to balance or improve the preasure in the ducts that arent blowing enuf
Apr 04, 2010 | Ruud UBHC Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
NO COLD AIR BLOWING TO REFRIGERATOR
The fan in the freezer blows its air through the COILS in the freezer. If the coils are plugged with frost, there will be no breeze coming into the fresh food compartment. One other thing i have seen on Amana and Sears, is that the fan slips on the motor shaft. Make sure the fan blade is tight on the shaft.
May 04, 2009 | Amana ARS266KB Side by Side Refrigerator
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
