Question about Tappan MEF500 Electric Kitchen Range
I want to convert a tappan stove to lp gas.
Model # 30-2249-00-04
  • 943 Answers
Hi thanks for the question the brass fitting at the burner unscrews to change from natural gas to lp if its screwed in all the way back that off till you get a nice blue flame do it to all burners thanks the appliance doc
Posted on Sep 25, 2008
I just converted a Tappan stove to lp and cant get to light. It acts like no propane is getting to the burners and pilots.
HI, Things to check. Did you reverse the cap on the regulator? Adjust the oven orfice by turning it clockwise until it reached the bottom of the threads? Some mofels have a small shut off on the gas valve as well.
Change the burner orfices?
Make sure the gas shut off valve is turned on all the way?
Just a check list. I hope this helps you.
Vic
Jun 06, 2009 | Tappan MGF500PBW Gas Kitchen Range
Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Feb 05, 2009 | Tappan TGF320 Gas Kitchen Range
Converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
Jan 05, 2009 | Kitchen Ranges
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Dec 15, 2008 | Kitchen Ranges
Convertion to LP
Generally, there is a kit to do this. Contact the manufacturer.
Dec 28, 2007 | Ovens
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range
Most likely has "ON PILOTS" As opposed to (electronic ignition/ Ignitors).. Change the stove to a more efficient model and being gas do "NOT" Do it yourself Period!.(Please)..Install should be tested and approved..
Call a local professional specialized in LP/Natural Gas Appliances. Flex lines on older Stoves tended to break down causing leaks as well as older construction codes where Black pipe feeds and shut-off valves break down after time. Sorry for the Negative info but Ive seen some Slum-lord homes in my days doing service calls.. Keep it shut off until you can get it fixed professionally..
Aug 08, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan MEF500 Electric Kitchen Range Logo
305 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
