Question about Canon PowerShot SD1000 Digital Camera
Card locked i have a camera model canon powershot sd1000. when i put memory card in my camera its shows card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
Posted on Oct 01, 2008
I have a canon SD1000 digital camera and I was looking at my photos and they showed up fine. When I switched to take a picture I got error 24. What is this?
Please remove your battery and the memory card, transfer all your photos into your PC and save. Now format the memory card and replace on the camera. Replace the battery and switch on to shoot. If the fault occurs there is fault in the CCD- the camera optical device- or on the main control board. It is ideal to take an opinion with the Canon support center to estimate.
Aug 23, 2011 | Canon PowerShot SD1000 Digital Camera
We took the disk out of the camera and put it in the computer nothing came up, so i put it back in the camera and know the disk says error memory lock
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 04, 2010 | Canon PowerShot SD1000 Digital Camera
When I turn on the camera it is showing "Card
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try a different card.
Oct 29, 2010 | Canon PowerShot SD1000 Digital Camera
When iwant to farmate my sd card of sandisk it shows protected can not be formated
Take your memory card from camera and check the write-prevention switch. You can see it at the left side when looking at a card from the top. Move the slider switch away from LOCK position.acf7eb1.jpg
Jun 21, 2010 | Canon PowerShot SD1000 Digital Camera
My Canon Powershot sd1000 is locked up. It turns on but will not take pics and I cannot view images. It is locked on one picture.
Check the lock switch on the side of the memory card. That is usually what causes the situation you are describing. It may have moved to the locked position accidently
Sep 27, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Memory card is locked w. Canon Powershot SD1000
Your Sd1100 is compatible with a 4gb card, so that's not the issue. If the lock-switch is in the correct position, the only logical conclusion (which you have already come to.....good troubleshooting on your part!) is that the camera is busted. Send your two "friends" the bill. What a drag.
May 27, 2009 | Canon PowerShot SD1000 Digital Camera
Canon sd1000 card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 03, 2008 | Canon PowerShot SD1000 Digital Camera
Memory Card
b32f20a.jpgPowerShot SD630
Camera will not power on with a memory card installed.
1. Try another memory card and contact the memory card manufacturer 2. The PowerShot SD630 requires repair service.
This information sourced from Canon Support Forum page here
Jun 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
157 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
