When I slap the side of my trunk my subs start to burp.
  • 31 Answers
Make sure all the connections are tight, especially if you have any of those big-can power capacitors. BE CAREFUL if you are using metal tools to do this, because if you accidently cross a positive terminal anywhere to ground, most ESPECIALLY the ones across the tops of the power capacitor/s, the tip of the tool may be vaporized. Wear a glove too.
Posted on Sep 27, 2008
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Dec 31, 2014 | Paradigm Audio Players & Recorders
Muddy or burping sound coming from M&K V-2B subwoofer when music starts. What's wrong?
Bad connections and or your sub woofer has a "blown" voice coil. You will need a new speaker if the coil has blown.
Oct 14, 2013 | Car Audio & Video
My cuisinart keurig coffee maker won't brew. It
Try this.
There are a number of ways to descale a brewer, the least expensive being to run some vinegar through the machine a couple of times, and then run cold water through a few more times to rinse it.
However, simply trying to clear the lines often doesn't work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Jun 03, 2013 | Coffee Makers & Espresso Machines
Keurig special edition b60 prime problem? My keurig now has the prime message showing up. I have ran through all of keurigs trouble shooting and none of it has worked. The prime message will go away...
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Apr 21, 2013 | Coffee Makers & Espresso Machines
Apr 21, 2013 | Keurig B60 Special Edition Brewing System...
All lights blinking, even when water in,etc., why?
It is not priming... give it a few good slaps on the back to "burp" it...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 02, 2011 | Coffee Makers & Espresso Machines
What is mean when it says to prime?
It means that there is air stuck in the system... give it a few good slaps to burp it...
heatman101
Aug 28, 2011 | Keurig B50 Coffee Maker
Descale light stays on and the rubber washer on tthe top spikeseems to be part of the problem. help me
We have a Keurig ourselves and were stumped when we first saw that descale message on the brewer.
Jul 31, 2010 | Keurig B60 Coffee Maker
Can the sony xplod 1000watt amp be bridged for more power to just one sub? also what problem would cause a subwoofer to make a slight burp noise whenever the car is shut off or into the non accessory...
This amplifier can only be bridged for a single subwoofer with an output rating of 380 watts bridged. The amp is not rated for 1000 watts.
The burping noise you here is the electronic switch discharging power off on the large capacitor that are used in high performance amplifiers. Regards, rcampsr
Feb 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
Rattling in water line to refrigerator
it is a home plumbing issue not a problem per say with the ref. it just happens to be the end result, nothing that can be added to the ref to stop it
Mar 21, 2008 | Whirlpool ED5SHAXM Side by Side...
19 people viewed this question
 Grubhead
Grubhead
