Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Coffee is not coming out
I turn on the machine and the lights start working. The middle light starts to flash and after it stops I usually just push the middle buttom to make coffee. It starts to grind but nothing comes out. Eventually the middle red light comes on. The are polenty of beans.Any ideas?
  • 1 more comment
  • lyndamaybury Feb 01, 2009
    Cleaned everything thoroughly, but doesn't put coffee out. clicks, grinds, makes the gurgle sound, spits out a teaspoon of coffee, and then the red light comes on. Note, will give a full cup of hot water.
  • copernic Feb 02, 2009
    I got the same issue.  Tried re-setting including priming but no dice.
  • Anonymous Feb 23, 2009
    I have the same problem with our Vienna SuperAutomatica and the recommended solution does not resolve the problem. Please advice!
  • 515 Answers
take out the brewing unit and clean it.
Make sure all parts is on place, try to open the steam knob and make a full cup of water (tea).
Let me know if you need more help
Best regards
/Mirran
Posted on Sep 25, 2008
Keurig Elite B40 not responding after "add water" and "heat" and "power" lights start flashing
Unplug the unit to reset it. That will give you a short term solution. I had the same problem, my machine is only 4 months old. They sent me a new one. I was told that there is no way to fix the problem for good. The unit is defective. Luckily I registered my machine right after I got it, and I kept my receipt They sent me out a new one, free of charge! It took about a week to get it..
Aug 21, 2012 | Keurig Elite B40 Coffee Maker
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
It is a new Saeco Odea Go machine. Every time I turn it on the indicator lights flash up and down successively and a half inch of water comes out of the coffee spout. The light is then in the ready...
What will the machine do when you turn it on? The green light will start flashing for warming up phase. When it reaches the working temperature, all the lights start flashing in anticlockwise direction and the brew group moves up and start pumping water to rinse the system.Of course half an inch of water will come out from the spout. That is normal.
Sep 10, 2010 | Saeco Odea Go
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Red warning light does not go off
use the end of a turkey baster to push water through the hole in your water bucket....do this a few times while having the hot water nozzle on. This fixes it for me.
Oct 17, 2006 | Saeco Vienna Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
237 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
