Question about Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher won't start
I have a Kenmore Ultra Wash dishwasher. I have power running to it, but when i shut the door on it...it still won't start a cycle. I pulled it out and everything seems to be in order. Does it have a reset button on it? Any ideas on a solution?
Thanks, Phillip
  • 1 more comment
  • djcasey Nov 21, 2008
    I opened the door shortly after starting a load (did not hit Cancel button). I put in that last spoon, and restarted. I believe it started up but later I came back and it was clear the cycle did not go for more than a minute at most, and the panel is dark, pushing buttons does nothing. I did pull the fuse for 15 minutes and replaced it, tried again, still nothing.
  • angielaurel Nov 23, 2008
    i opened the door shortly after starting a cycle without canceling and now the light says it is washing but it isnt doing anything, it wont let me cancel the cycle and start over....what do i do???
  • jameska Dec 19, 2008
    Hi - I'm having a similar problem. I have a Kenmore Ultra Wash. When I close the door to push settings, there is a dash (symbol) on my little screen. None of the buttons work when i push them, they don't even light up when i push them. The only thing i can get to work is the lock (you press one of the buttons for 5 or 6 seconds and it will lock the dishwasher.
  • 750 Answers
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but when you shut the door on it...it still won't start a cycle. Does it have a reset button on it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
Posted on Sep 25, 2008
My start/resume light keeps blinking
Count the blinks. If 7 blinks, this usually indicates a problem in the heater circuit. You have to be able to check your heater, heater thermostat and possibly your control board.
sometimes you can shut power off to dishwasher for 10 seconds and this may reset your control and allow your dishwasher to run until the fault reoccurs.
Mar 08, 2015 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore ultra wash dishwasher
The only time I have run into something like this when trying to help a client, we found that there was a shut off switch up on the wall above the counter. It looks just like a light switch and sometimes someone accidently turned it off and the dishwasher no longer worked. I do not know if you might have a situation like that but maybe it might help and save you a service call.
Jul 30, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
My detergent cover broke
yes u can run it just like that or vist sears.com for parts u need Here to Help Shaun
Nov 18, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore ULTRA WASH Portable Dishwasher Model 665.1784 leaks
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Sep 27, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
724 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
