We have an American Standard YCD240B3HAJB that will not ignite on start up every time. When it does it will shut down intermittently. We have tried testing everything we can think of and replaced the board and igniter. If someone has an idea let me know I am at my wits end.
Try using a jumper wire between w and red on the stat subbase. that will take the stat out of the equation , if it has a bad heat anticipator etc. if furnace fires every time and stays on stat is the problem be sure glow ignitor is positioned in the flame after lighting as it proofs flame on some models . also look for a needle like sensor sticking into the flame on some it also proofs flame. you can gently remove and clean with sand cloth and theyll work sometimes but best to replace if to coroded.
Posted on Oct 10, 2008
Radio and turn signals work intermittently on a 2005 wrangler
Im having the same issue and discovered if I jiggle the key in the ignition while turning the switch I got the blinkers and radio to operate. Shut it off and tried again, they work. but this has happened before and I think its more frequent. Im also thinking worn ignition switch. Hope it helps.
Apr 26, 2012 | Jeep Cars & Trucks
The circuit breaker for the outside unit of an American Standard central AC system started tripping and when reset only runs for about 15 minutes before shutting down again. It just started doing this...
It is tripping for one of two reasons. Either the a/c unit is pulling too many amps or the breaker is weak. If you have an amp meter then check the amp draw on you a/c, if it is pulling more than 24 amps then you need to have it serviced. If it is not pulling that many then you have a weak breaker and need to replace it.
Jun 28, 2011 | American Standard Heating & Cooling
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
2001 impala starts and dies It usually starts the second time and stays running. also stalls intermittently while going down the road. have replaced mass air flow sensor, crank sensor, removed throttle...
this sounds like a fuel issue, sometimes can be difficult to diagnose because its obviously being intermittant. whether its a fuel pressure regulator or the pump itself, i feel the most likely cause is the pump itself losing prime and thats why you have to try 2 times or more to crank because you are creating pressure from the fuel tank everytime you try to crank, this would also be a possibility as to the shut off if its getting hot than shutting down and than your able to start it back up. i would put a fuel pressure gauge on the vehicle and watch my fuel pressure readings to make sure they are staying true. if the fuel pump checks out than it will be an ignition or computer issue, i hope this helps
Feb 12, 2011 | 2001 Chevrolet Impala
Equipment: American Standard/Trane model THS 120A960B2 Horizontal- Intermittent electronic ignition. Fuel: LP Problem: burners ignite then turn off. This on /off cycle repeats 4-5 times and then...
Could be flame sensor. I dirty flame sensor will cause this problem. Flame sensor is rod that is in burner, should be able to remove and clean with steel wool or dollar bill. Usually has white film on sensor preventing it from reading flame. Not sure how American Standard is but sensor normally has 1 screw holding into place in burner box. If you can get at it, it is easy to clean.
Jan 24, 2011 | Goodman Heating & Cooling
1989 Celica GT Convertible Replaced ecu, ignitor, distributor assy, wires, and plugs. Runs great, but intermittently will shut off (no spark) at a light when in drive (cranks, won't start). Battery is...
something is heating up it could be the ignition relay or a bad ignition switch. relay can over heat and stop working this would take some time to cool down again, ignition can do the same some times you can feel the heat on the key when removed.
Jun 29, 2017 | 1989 Toyota Celica Liftback
I have an American Standard Freedom 80 furnace. When I turn it on it runs and runs and then shuts down and then the cycle starts again. It runs but never ignites. I was wondering if there is anything I...
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Oct 27, 2009 | Heating & Cooling
Flame wont stay on and have replaced the flame sensor
You have a limit switch that is tripping. I bet it is the flame roll out switch that is very close to the burners. You can bypass this switch to check if it is the one causing the problem by removing the two wires going to it and installing a small jumper wire between them. If the unit starts up, then that's the problem and if not, check all of them. But that's pretty much the only thing it can be. But, you need to double check that the unit is being told to come on and not cutting out intermittently. I doubt it though!
Mar 23, 2009 | American Standard 2083.102 Standard...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
