Question about Sony Playstation 3 (PS3) Console
Ps3 accepts disk then nothing
Took cover off check pwr. to drive good when screen comes on it is black/white and blury but still funtions just no actions is there a disk i can put in? alto if it dosnt play anything? then mabe boot from? lan. or usb? any ideas? thank you
  • 45 Answers
I'd suggest downloading the LATEST firmware and installing via USB, and if that doesn't work, call Sony. There's not a lot you can do about it. unfortunately mate
Also, assuming that the firmware was the culprit, and it wasn't just a drive failing coincidentally. It does happen. hope this helps.
Posted on Sep 24, 2008
Ps3 slim not accepting disks !!!!!
Send it to Sony this happened to a friend and they sent it away and came back good as mew
Nov 20, 2011 | Sony PlayStation PS3 Slim 120GB Bundle...
My ps3 slim blue ray drive will not accept discs. it wasnt reading them so i took the drive out and tried cleaning it but forgot my game was still in it so i removed it manually. when i put it all back...
OK, all the answers I see here don't look like they was reading your problem and what you did. You most likely should take it back apart and put the disc back in it that way. Since you took the disc out the PS3 thinks there isn't and is a disc inside. When you press the eject button it's not going to reset the disc arms inside because there isn't a disc in there and that white thing is there to keep a disc from going in with a disc inside even though there isn't one. You should go ahead and order another laser and when you take it back apart change the laser also slim PS3 are more common on the laser going bad I've changed alot of them. But when you change that make sure you either put a disc back in or move the arms and slides to where it's ready to accept a disc when it's put back together.
Nov 01, 2017 | Sony PlayStation 3 Slim Black Console
Took apart blu ray drive on ps3 now wont accept disks
If you took it apart because of a stuck disk then you need take the deck apart again leave the 2 covers off place a disk on the spindle turn your console on and then press eject.
Mar 14, 2011 | Video Game Consoles & Games
My wii turns on to a black screen and stays there
as a manufactuer of the wii console the internal scart funtion may be damaged due to, to much use of the console. Basically not being able to be used
Sep 19, 2009 | Nintendo Wii Console
Welcome screen come up then nothing...............
Please try:
  • turning your PS3 SYSTEM ON BY HOLDING THE ON/OFF BUTTON and using the AV cables (red white and yellow, it will restore your audio and video settings).
  • changing your Hard Disk for another one (spec: SATA 2,5'' 5400rpm)
  • taking you Hard Disk off of the system and formatting it in a PC platform .
else, consider taking the system to a assistance center for possible hardware issues checking .
You can access warranty forms here:
https://service.us.playstation.com/online-request.asp
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
The cd wont go in the console i push it in and it wont take it wat do i do
Have you ever performed a force eject from the PS3 by holding down the eject button
If you have this can cause the tack to become unaligned and thus rejects the disk
If you are under warranty that's the way to go if not a repair shop
Or if you do know your way around a PS3 bluray drive then here's how I align my drive
    1. Drive teeth can get terribly misaligned because of worn gear teeth, you may find it easier to reassemble the drive in the loaded position.
    2. With your Blu-ray drive open, remove the platform that holds the rollers. The only one screw is circled in red. Be careful about touching the plastic bumpers circled in blue. Short instructions under "Tips", in case you do.
    3. Twist the white gear denoted with yellow clockwise until the the gear separates from the black platform on the left hand side of the drive. Practically every gear in this area moves every other gear, but the white one seems the easiest to twist. Keep twisting until the two catches circled in green are completely lowered.
    4. Realign the black platform and twist the white gear counterclockwise until the two catches are fully raised. These catches keep you from inserting a second disc. You should not have to twist the white gear fully counterclockwise and it is a good idea not to. Make sure the left black platform is not tight against anything - especially the stuff towards the bottom edge.
    5. Pull the rollers outwards as the pink arrows indicate and screw the roller platform back onto the drive. When this is done, your rollers should be slightly loose. Work with the rollers and the white gear until they were just tight enough to loosely hold a CD as though the drive were reading it.
    6. Insert a junk CD along the top half of the drive as though the drive were accepting it. Pay attention to how the junk CD locks into place as though you still cared about it.
    7. While holding the CD in its loaded position, pop the top half of the Blu-ray drive onto the bottom half. You can shake it lightly, but if it doesn't come together smoothly, something might be misaligned. Go back and tweak until it comes together with relative ease. Don't forget the white magnet.
    8. Screw everything (that you feel like) back together, boot up your PS3, and eject your junk CD. It should come out smoothly and be re-accepted smoothly.
    If this has been some use to you then a rating would be great
    Thanks
    Jul 22, 2009 | Sony Playstation 3 (PS3) Console
    Game disc will not eject itself (eject not
    Or is you do know your way around a PS3 bluray drive then here's how I align my drive
    The photo I can provide if you wish cant post it here
    Thanks
    Ps3 all black when i turn it on
    ok a long shot but i did read somewere that if u hold down the power button for 10 seconds it detects or calibrates to the current TV that is connected its worth a try if nothing else, if this didnt help sorry but if it did enjoy :)
    P.S. i dont know if the console needs to already be running to do this.
    Nov 03, 2008 | Sony Playstation 3 (PS3) Console
    PS3 Disk Read Error
    its a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. i'm getting my new one tomorrow. upset it broke but sony's replacement service is very good.
    Sep 19, 2007 | Sony Playstation 3 (PS3) Console
    PS3 rejects disc's
    simple , try cleaning your disc first, then put in PS3...
    Aug 09, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    23 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
