Question about Linksys Wireless-G WRT54G Router
The lights are on but the linksys is not working
I have the linksys wireless-g model WRT54GS the wlan light is on and the internet light is on but the it's not working on the computer I put on a laptop and it still don't work and I put the hard wired to the computer and it still don't work and the ethernet light #1 light come on wen I put the hard wire I rand a system test from the program disk that it came with the linksys it say that it can't find the wireless linksys. thank you.
    Scholar:
  • 188 Answers
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Posted on Sep 24, 2008
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Problems with internet connection linksys wireless WRT54GS
hello i'd change it to belkin router good luck
shaun
Aug 24, 2009 | Computers & Internet
Wlan light is not lit on my linksys WRT54G wireless route.
ar eyou trying to get wlan? or just wondering about the light ? if you have wlan and no light its just a bad bulb then if its not enabled then enable it
Mar 21, 2009 | Linksys : WRT54GS Wireless-G Router W/...
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Help
You do not need the manual or CD
1. Turn off both the linksys and your modem
2. Turn on your and wait for the usual lights to turn solid
3. Turn on the Linksys and wait 30 secs
4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address
5. now connect with an Ethernet Network Cable and make sure the internet is working
6. Next Setup the Wireless Encryption, if you don't know how to do this, post and I will help
7. Disconnect the cable and Connect Wirelessly
If you have limited connectivity then next try this: http://www.howtofixanything.co.uk/howto-269.html
Jan 02, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Wireless-G Broadband Router
The WLAN light will normally blink if there is data passing through. Most often if the problem is that you need a reboot for the router to work again you will need to update the firmware of your router. You need to go to www.linksys.com then click on the top right search then look for your model number then select the option to WRT54G downloads. Search for your model and then download the firmware. After that on a computer wired to your router go to http://192.168.1.1 through Internet Explorer. Click on the administration tab then click Choose. Select the file that you downloaded then click on Upgrade. That should fix your problem.
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
141 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
